RV.Net Open Roads Forum: General RVing Issues: Dually tire service/installation
 > Dually tire service/installation
HighwayPilot
Miami, Fl
Posted: 05/27/22 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Hello all, we have an xplorer 230XL class B ( tires are 245/75R16 load range E)and it's time to change tires. we live in Miami, Fl. and I am able to purchase the tires online at Walmart and delivered to the house or tire shop. but I'am having trouble locating a tire shop to do the work(most don't want to deal with dually's). I was told by one shop he could do the installation but cannot balance the inner tires. Is that a possiblity? in other words, is he pulling my leg? Thanks for your inputs in advance.
Virgil, May & Fred (the yellow Lab) ">
BobsYourUncle
Calgary Alberta Canada
Posted: 05/27/22 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Pulling your leg....
Tires are balanced before bolting them on, after mounting on the rim. It doesn't matter if they are inner, outer or on the front.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
jmtandem
western nevada
Posted: 05/27/22 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Find another shop. Balancing the tires is done prior to installation.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
BurbMan
Indianapolis, IN
Posted: 05/27/22 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Most tire shops don't want to install tires that you bought cheaper online. If you want to buy the tires from Walmart why not have them shipped to the closest Walmart store and installed there? Otherwise, why not buy them from the local tire shop? That size is pretty common, you shouldn't have any trouble finding what you want.
momentum rv
Central Cal.
Posted: 05/27/22 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Find a "truck" tire shop.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
Durb
NW
Posted: 05/27/22 08:37am Link  |  Quote  |  Print  |  Notify Moderator
You could get Centramatic balancers for the rear. I installed them on my duals with balanced tires and they made a lot of difference. The instructions suggest not balancing the tires prior. The cost would offset your savings by buying tires at Walmart.
BruceMc
Oregon - Willamette Valley
Posted: 05/27/22 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I've dealt directly with "professional" tire shops that supposedly handled a lot of duals for commercial trucks, but came away with shoddy workmanship anyway. In a couple of instances, I purchased the tires from them.
Many times, I've had to take it back, explain how duals are supposed to be mounted on the hub, and that's after getting them to run a second balance.
Tire "professionals", indeed. It's easy to throw labels about.
There's an index hole (or pin) that aligns with the index hole in the rims. Then, the valves are supposed to be 180 degrees apart.
In my last case, they buried one of the inner valves - it wasn't even visible.
Idiots.
To Discount Tire's credit, they bumped other work, pulled the motorhome in and re-did all 6 tires, paying particular attention to the balance, then properly mounted them on the hubs. I checked their work before departing the second time.
The problem was a floor "manager" that was not qualified on the balancer was trying to help the workers with the work load. He learned his lesson - he should have stayed in the office, and let the qualified help do the job.
'16 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Previously:
'00 Four Winds 26Q Class C (Ford E350 V10)
'96 Kit Sportsmaster 212f Fifth Wheel/'93 GMC Sierra K2500
'91 SunLite poptop truck camper
and the first: a Wildernest flip-top canopy.
Posted: 05/27/22 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Find a mom n pop shop or used tire place if none of the chain stores will do it.
Or take them to a Walmart tire shop.
And it is no more difficult than doing tires on any vehicle. And those little tires and rims don’t even command a premium charge for mount and balance.
Dutch_12078
Winters south, summers north
Posted: 05/27/22 11:04am Link  |  Quote  |  Print  |  Notify Moderator
I've found having an appropriate quantity of balancing beads put in the tires before mounting easily solves the balancing issue. No machines needed...
Dutch
2001 GBM Landau 34' Class A
C Schomer
Pueblo West, Co.
Posted: 05/27/22 11:33am Link  |  Quote  |  Print  |  Notify Moderator
It's amazing how ignorant some tire people are. I've dealt with shops that swore the dual valve stems COULD NOT go straight across from each other because they would be out of balance. That's when I give them a lesson on the OLD duallies with the guide pins in the hubs. Craig
