RV.Net Open Roads Forum: New Roof Time! Can I just layer over the existing plywood?
 > New Roof Time! Can I just layer over the existing plywood?
211Racing
Texas Hill Country
Posted: 05/27/22 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Got an old, unkempt 2002 Tioga 25' Class C RV recently (really cheap). Fixed the mechanical issues. Now going after the roof. Whatever they last used for a roof membrane, it is almost completely gone. Bare plywood in many places. Some dry rot. Did exploratory surgery this morning with a hole-saw. See the images. The plywood forming the exterior roof and interior ceiling is approximately 3mm thick. Between that roof and ceiling is 3" of foam (presumably injected). The adhesion between the plywood and foam is very strong. What problems do I cause myself if I leave the current plywood in place, strip, clean and seal it, patch wherever needed, than lay down (put up) a new 5mm plywood layer on the roof and ceiling? This will be a low-use vehicle, mostly for day trips to motocross/hare scramble races (need someplace to cool off). I am willing to accept the added weight. Thank you for your insights and shared experiences.
[image] border="0" alt="[image]">
BurbMan
Indianapolis, IN
Posted: 05/27/22 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
That is a structural panel where the styrofoam and plywood is all vacuum bonded together. I would clean up the roof as you describe, then go over it with 1/8" (3mm) plywood so you have a nice clean surface, then get a roll of EDPM rubber membrane and cover the roof with that. Glue it down. Seal around vents, etc. with Dicor self-leveling lap sealant. If the rig had a rubber roof on it before there is probably trim around the edges you can reuse.
211Racing
Texas Hill Country
Posted: 05/27/22 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
That's what I wanted to hear.
Thank you.
RLS7201
The adhesives don't stick well to the old surfaces. Most times new lauan is used to get a good bond for the new roof membrane.
Dicor has been punishing RVers for years. Given time it cracks and leaks. If you're going to all that work spend a little more and use Sikaflex 715 for sealing around your EPDM roof. Sikaflex doesn't harden and crack like Dicor.
Richard
* This post was edited 05/27/22 12:32pm by RLS7201 *
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Cambria, California area
Posted: 05/27/22 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I suggest following Burb Man’s recommendations.
BurbMan
Indianapolis, IN
Posted: 05/27/22 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
I should also that when you cover with new plywood, glue it down with a good construction adhesive like PL Max (get it one of the big box home stores). It's very strong yet flexible and will make the new plywood part of the structural panel. This way you only need a few staples to hold it while the PL dries.
The Lance that I rebuilt (link in my signature) had an aluminum roof, that's another option if you can get a roll of aluminum wide enough to cover with no seams. The aluminum would be sturdier than the rubber but much harder to work with outside of a factory setting.
bukhrn
Lanexa, Va
Posted: 05/27/22 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
I take it you have found no evidence of leaking, (interior or exterior), no signs of mold.
2007 Forester 2941DS
2014 Ford Focus
211Racing
Texas Hill Country
Posted: 05/27/22 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not in deep enough into the tear down to get a reading on leaks or mold. I'll remediate that as it appears.
Veebyes
Posted: 05/28/22 08:56am Link  |  Quote  |  Print  |  Notify Moderator
JMO but if the existing plywood is in good condition I would consider giving it a dose of preservatives & go from there with whatever you deem good for top coatings or coverings.
2007 Alpenlite 34RLR
B.O. Plenty
Minnesota
Posted: 05/29/22 03:29am Link  |  Quote  |  Print  |  Notify Moderator
Look up AZ Expert on You Tube. He has several roof videos.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
