RV.Net Open Roads Forum: Country Water Fill - Class C Jayco
 > Country Water Fill - Class C Jayco
mleekamp
Washington, IL
Posted: 05/30/22 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Having had TT's for 20 years, I guess I was spoiled by filling the fresh water tank with a hose via gravity through a simple opening. We've had our C since late 2018 and for the first time this past Sunday (Memorial wknd), I needed to fill the fresh water tank with another 5 to 10 gallons of water for our last night. I carry an empty 5 gal container, no problem. Filled it nearby.
The book states that I put the hose in the container, and attached to fresh water inlet, I did. I turned the valving to indicate "country fill", and turned on the pump. It's supposed to suck the water in, according to the book.
But 20 mins of it, and only 1.5 gal went in. I fiddled with the hose and got maybe another couple quarts after another 15 mins. I feel like I'm going to burn up my pump.
What gives? I guess I expected it to work better. "Normal" filling has pressurized water, and they call it "city fill". I get it. What am I doing wrong here?
Bumpyroad
Virginia
Posted: 05/30/22 06:15am Link  |  Quote  |  Print  |  Notify Moderator
to "suck " fluid in could be a winterizing system to add antifreeze to system?
city water pressure should push water in the fresh water fill unless that valve is stuck???????????
bumpy
toedtoes
California
Posted: 05/30/22 07:02am Link  |  Quote  |  Print  |  Notify Moderator
There are several suggestions on the Jayco forum.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
stickdog
Somewhere, USA
Posted: 05/30/22 09:16am Link  |  Quote  |  Print  |  Notify Moderator
I found it easier to buy a 12 Vt transfer pump.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
stickdog
Somewhere, USA
Posted: 05/30/22 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Sjm9911
New Jersey
Posted: 05/30/22 09:43am Link  |  Quote  |  Print  |  Notify Moderator
There is probably a way to fill it from the city water port also. If you have a hose with pressure. I feel your pain, no gravity feed on mine, and to switch it over the controlls are under the couch, that is under the rear slide bed. Plus, I can't see them well, so I turn things untill I hear the water flowing to the pump. Check the manual, try it both ways at home, then mark the valves.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Sjm9911
New Jersey
Posted: 05/30/22 09:45am Link  |  Quote  |  Print  |  Notify Moderator
bumpy
They probably have both, and the winterizing system is the only way to fill it without using a hose. Unless you get a seprate pump as stated above. Not having a gravity fill is not fun.
opnspaces
San Diego Ca
Posted: 05/30/22 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe the hose had an air leak at the fitting at the fresh water inlet
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Posted: 05/30/22 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry I don’t have a suggestion, however I’m sort of amazed that there are apparently numerous “normal” RVs that you can’t just fill the fresh water tank like “normal.”
Weird…not something I would have guessed.
bobndot
Posted: 05/30/22 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
What's new isn't always better. I had easy access to my water tank and was able to fill it from inside the rv using a mod that i once viewed.
On a previous rv , i found it easier to cut a hole on the top of the holding tank and use a marine deck-plate to seal it. That gave me the option to fill using a pressurized garden hose or gravity fill via bucket. It also made it easy to clean the inside of the tank. 8” hole with deck-plate.
You could also install an old style gravity fill port and fill tube to the tank. Just cut a hole and seal it like they always did at the factory. They work !
