RV.Net Open Roads Forum: Class C Motorhomes: Sunseeker classic questions
 > Sunseeker classic questions
Bandaid
Holcomb, New York USA
Posted: 05/30/22 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2021 Sunseeker and I have an air leak in the passengers side airbag system. I have it narrowed down to the fitting on the top of the airbag, however, getting to the location of the fitting appears to be difficult to say the least! Has anyone tried resealing this fitting and what did you have to remove to gain access to the top of the bag?
My unit also came equipped with the Bilstein shocks. While under the unit looking for a way to access the airbag fitting, I noticed the top of the shock goes through a metal sheet. How, or where do you gain access to the top of the shock should it need to be removed and replaced?
Ratracer.
klutchdust
Orange, California
Posted: 05/30/22 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Having spent time repairing various models of RV's from tent trailers to Provost I can tell you that there is no set formula to answer your questions . Often I have to just stare at something
and consider all possibilities. The air bag may need to come off to gain access to the top. Interesting the shocks go into the metal shielding. Doubtful there is any access from inside.
The sheet metal may have to be removed. Post some photos of both and see what we can come up with.
* This post was edited 05/30/22 12:48pm by klutchdust *
bobndot
Posted: 05/30/22 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
If i remember correctly, you have to remove the bag being there is little clearance on top.
An interesting video shows a spring swap eliminating the need for AB’s. I did this on one of my trucks and it worked real nice. No more AB’s for me.
This youtube shows the springs for a class C at the 12+ min mark.
https://youtu.be/1-2BbIYorgI
