RV.Net Open Roads Forum: Tech Issues: Low point drain valve question
 > Low point drain valve question
Posted: 06/02/22 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
My bad, didn't see your post before mine. If off the pressure side, give it a try. I bet it works just fine.
bucky
Raleigh metro
Posted: 06/03/22 04:57am Link  |  Quote  |  Print  |  Notify Moderator
If you've got fresh connected to city water why are you not using the city water direct to the pressure washer?
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Missionstreet
PA
Posted: 06/03/22 07:51am Link  |  Quote  |  Print  |  Notify Moderator
This would be for instances where I do not have the "city" hookup.
2112
Posted: 06/05/22 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Come back and let us know if it worked
2013 KZ Durango 2857
