RV.Net Open Roads Forum: Fifth-Wheels: Disc Brakes - Saved me $$$$
 > Disc Brakes - Saved me $$$$
ford truck guy
Pennsylvania
Posted: 06/04/22 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder if they can be retrofitted onto Kodiak 8K systems?
Just Curious
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
4x4ord
Alberta
Posted: 06/04/22 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Disc brakes on my fiver cost me a few hundred bucks last summer. My wife was towing the fiver with the motorcycle trailer on behind and going like a bat out of hell when she came over the crest of the hill and saw the turn off to the campground. She hammered on the brakes and made the turn. When I came along a few minutes later and saw the rubber left on the highway i immediately remembered that I forgot to adjust the brake controller for her before turning her loose ….. trailer tires were completely shot. Blasted disc brakes!
2022 F350 SRW Platinum short box 4x4.
B&W Companion
Learjet
Louisiana
Posted: 06/05/22 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
The problem I have with my Kodiak 8K and Dexter 3.5K is they are both single piston calipers and they wear the outer pad WAYYY faster than the inner. I keep the slide pins properly lubed.
They LOOK impressive. Only negative I see is the hub cap is not threaded to allow for oil bath.
The disc (rotor?) part slides over the lugs, so I guess you could change the hub to one with an oil bath.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
Cummins12V98
on the road
Posted: 06/05/22 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Separate rotor makes it an even better system as mine are one unit hub and rotor.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Just Curious
That would make the IS system REALLY nice!!!
philh
Belleville MI
Posted: 06/05/22 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
We almost got into an accident coming home from FL this spring. When I say almost, it was a few inches. Wife was driving and I saw the issue developing before she did. I had felt my new disc brakes were slow to activate, and this event really put on steroids the need to bleed the brake lines. Wife was standing on the brakes and I could feel the trailer pushing us closer and closer until it finally built up enough pressure and ****, it stopped right there.
The next place we were stopping, I had an opportunity to bleed the lines, and there was still a ton of air in the lines. Now, when I need it to stop RIGHT THIS SECOND, it stops.
ford truck guy
Pennsylvania
Posted: 06/05/22 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Just Curious
That is the only thing I believe that would make the IS better....
blofgren
Surrey, B.C.
Posted: 06/05/22 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I totally agree with the comments here; I was absolutely shocked at the difference. Our current fiver is the largest and heaviest that we have owned, yet it stops in a fraction of the time that our others with drum brakes did. I will also not have a fiver without discs again.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
ACZL
UPstate,NY
Posted: 06/06/22 12:58am Link  |  Quote  |  Print  |  Notify Moderator
Are the disk brakes a retro fit? How do they work with trucks power thru cord? If a DIY job, how hard and long does it take? What info is needed to order them? I really like Learjets set up. TIA
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Learjet
Louisiana
Posted: 06/06/22 06:59am Link  |  Quote  |  Print  |  Notify Moderator
My old trailer I got the kit from here...
https://www.performancetrailerbraking.com/
Also, check out Etrailer...both of these sites have plenty of info.
