BurbMan
Indianapolis, IN
Having lived on Long Island for many years and towed a 34' TT all around the area, I can tell you that it's impossible not to...if you leave the required space behind the vehicle in front of you, somebody will jump into it. More than likely will proceed to hit the brakes as well. Spend any amount of time on the highways in the NE corridor and it's baffling the stuff that people do.
I've only had 1 incident like that on I-95 just north of Stamford, CT and also was fortunate to stop. Thankfully it wasn't raining that day.
TT was 8500 lbs and I always kept the Prodigy dialed up so that the TT brakes led the truck brakes. For me, changing them out to self-adjusting drum brakes was a big win. It's a sad commentary on the RV industry when you're excited about upgrading the braking technology on your 2008 RV to 1960 standards...
You're absolutely right, though...big, heavy 5ers should come from the factory with disc brakes.
edited 06/03/22 07:43am by an administrator/moderator *
JTrac
Oklahoma
I had gotten used to the disc brakes on our previous trailer and was disappointed when the only option on the Pinnacle we got a couple of years ago were drum. I thought I could deal with it until I made my first panic stop. I called Performance Trailer Braking and had them come to my house to do the conversion. What a difference it made. My drive is much more relaxed knowing I have much better braking power.
JimT
2020 Jayco Pinnacle 32RLTS, 2020 Ford F350, Platinum, 6.7 diesel, 4X4, CCLB, SRW, 12,400 GVWR
ford truck guy
Pennsylvania
BurbMan wrote: bucky wrote: I agree that they are better. Maybe you were following too close to begin with?
You are correct about the NE corridor, although the PA drivers are a smidgen better than NJ who are a smidgen better than the NY drivers...
Was I too close, I guess that would be subjective, in my eyes, no.. I always keep MY safety BUBBLE around me, but like Burbman stated, it is difficult in this part of the country.. Pulling a 17k fifth wheel primarily around the NE and you get you aware of ALL possible scenarios... Not to mention my wife didn't tell me I was too close, so I guess I was ok ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
JTrac - Jim, I am surprised the the Pinnacle line does not offer the disc option?? I had Performance Trailer Braking do the install back on my first Redwood, back when Ron was the owner of the company, they were and still are a good company.
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Learjet
Louisiana
I agree disc brakes only...I converted my old trailer and ordered the new trailer with disc brakes...they are great!
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
JTrac
Oklahoma
Joe, not an option on my 20 model but were starting with the 21's. PTB did an excellent job. We've had them for a year and a half now and definitely worth the cost.
Cummins12V98
on the road
Learjet wrote: I agree disc brakes only...I converted my old trailer and ordered the new trailer with disc brakes...they are great!
![[image]](https://i.imgur.com/JwB2rsul.jpg)
Looks like a nice setup. I bet the brakes work great with the twin piston calipers.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Learjet
Louisiana
they are actually 4 piston calipers, the line connects at the inner top, crosses over and then there is another crossover line at the bottom for the inner calipers with another two pistons.
They are much smoother and stronger than my single piston calipers on the old trailer. Went from 6.5 on the brakes to 4.0
Just looking at my own picture and thinking about it...This set up eliminates the pins the calipers usually ride on and the stick problem they can have.
here is another picture...
edited 06/04/22 01:18pm by an administrator/moderator *
ford truck guy
Pennsylvania
Learjet ,
Is that factory install? or aftermarket? Those quad piston calibers look great !
Learjet
Louisiana
yes, factory Jayco installed upgrade option. They are Dexter brakes.
One pin and the pads come out....hope they last...they are @ $500 for a set of pads for 4 wheels at Etrailer.
edited 06/05/22 06:50am by an administrator/moderator *
Cummins12V98
on the road
The problem I have with my Kodiak 8K and Dexter 3.5K is they are both single piston calipers and they wear the outer pad WAYYY faster than the inner. I keep the slide pins properly lubed.
They LOOK impressive. Only negative I see is the hub cap is not threaded to allow for oil bath.
