magnusfide
On the Road Again and Again and Again...
Turn Your Regular Grill Into a Smoker in 5 Easy Steps
"The only time you should fear cast iron is if your wife is fixin' to hit you with it."-Kent Rollins
First law of science: don't spit into the wind.
Magnus
Southern California :(
Interesting. TY for posting.
BobsYourUncle
Calgary Alberta Canada
Cool! I'd like to try that, looks and sounds tasty.
Thanks for posting.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
folivier
Southeast Louisiana
I've been using a Carpathen smoker tube for a few years now and it works fantastic with pellets to produce lots of smoke. There are many different brands out there.
dieseltruckdriver
Black Hills of SD
We have one of these at home for cold smoking cheese etc. and one in the 5er that we use with our Weber Q120.
LizzQ smoker tube.
Filled with wood pellets ours lasts around 5 hours. I use less for shorter smoke times. Fire it up for a while before starting your food, and they get great results.
Just a tip from experience, if you are going to cold smoke some cheese in a Weber Q100/1000 size grill, build a foil heat shield to protect the cheese from the radiated heat in the small space.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Redcatcher70
Beebe, AR
I have been doing this for several years, on a gas and charcoal grill. Nice way to do ribs, chicken, Cornish hens, and even meat loaf. I don't really recommend doing large pieces of meat like a whole brisket, large pork butt, or 20 lb. Turkey unless you use a gas grill where you can regulate the temp.
Using a charcoal grill with large pieces of meat, and trying to regulate a low temp takes too much babysitting the grill, JMHO.....
Dave & Pat
2008 Hi-Lo 19T
2004 F250, XLT Crew Cab, V10, finally, enough power!
"No kids, no pets, made it to retirement"
Sjm9911
New Jersey
It works and will add a bit of smoke, but its not as good as a smoker. I hace herd of those tubs and they seem to be a good idea also. So, maybe good whild camping. But at home , the pellet smoker is so easy!
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Riley White
Wow, that's useful. I like all such DIY transformations
magnusfide
I bought a smoker box similar to the one from the article and like it. Mine is cheaper by Char Broil. I like the fact that I can use chips and not be limited to pellets like the other smoker tubes.
We perfer a little less smoke than some people do so it works pretty good plus it's portable for our small mh.
propchef
NORCAL
Nice. Do you soak your wood chips? I stopped doing that years ago and I know its somewhat controversial among some cooks.
Has anyone used the flavored chips from Kingsford? I can't bring myself to buy any of those
