Trent1980
Louisiana
Hello, new to forum, have had camper for 6 months, 4 trips in it. From south Louisiana, it's hot! Was wondering if anybody runs ac off generator while towing to location? Any help or info would be appreciated! Thanks!
midnightsadie
ohio
wouldn,t the cold air get sucked out?
QCMan
Independent Republic of Horry
We are from SC and travel west and south a lot. We set up, turn the ac on and take the dogs and us for a long walk. Get back and the unit is below outside temp. Get dinner started and enjoy the rest of the cool down.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
katysdad
Virginia
The class A's and C's run while on the road because the dash air doesn't cool the whole rv. Just be sure your generator location vents the exhaust so it does not get pulled into the trailer or tow vehicle.
Dodge Ram 3500 DRW Diesel
pianotuna
Regina, SK, Canada
In hot weather, I generally run the roof air for an hour or so before stopping for the day.
Regards, Don
ROBERTSUNRUS
Salem, Oregon
Hi, I have my generator mounted in the bed of my truck, by the tailgate. I installed a generator inlet on the front of my trailer just for that purpose. This is so I can cool my trailer at rest stops, at boondocking sites, power outages in camp grounds, and to cool my trailer before I get to a camp ground in hot weather.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
1320Fastback
Vista, Ca
I've ran the AC and Gen while towing. Worked fine.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
Y-Guy
Tri-Cities, WA
We've run it with our 5er and our Class A, no issues. We'd fire up the generator on the 5er about 45 minutes from our campsite to cool things off, but we were camping in 95° heat too.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
dodge guy
Bartlett IL
If you can mount the generator safely then yes that would be great.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
valhalla360
No paticular place.
dodge guy wrote: If you can mount the generator safely then yes that would be great.
Not just the generator but the cord also (not so much of an issue with a built in generator)
If traveling in really hot weather, we just open everything up to flush out the hot air. Assuming it's not rainy or dusty, doing it 10-15min before arrival then driving will be even better. Then turn on the air/con.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
