RV.Net Open Roads Forum: General RVing Issues: Tire exploded in Florida
 > Tire exploded in Florida
Page of 5
solman
Deep in the heart of Jersey
Posted: 06/04/22 05:21am Link  |  Quote  |  Print  |  Notify Moderator
I have the Tire Minder A1A. They measure temp as well as pressure. I find the pressure readings to be off a few pounds vs my gauge. Still good to have as I scan all the tires while underway every so often.
These systems are not perfect but better than nothing at all.
Yes I did mean the Goodyear Endurance tires.
Solman
2011 F-250 6.2L 4x4 3.73 8'bed
2020 Keystone Cougar 5er 315RLS
pullrite 16k hitch
CapriRacer
Somewhere in the US
Posted: 06/04/22 05:36am Link  |  Quote  |  Print  |  Notify Moderator
My first reaction was to ask how old the tires were, but I see in OP's profile that they have a 2020 Keystone trailer listed - so 2 to 3 years old.
Second, we haven't ruled out a road hazard. A photo might help us here.
CapriRacer
Visit my web site: www.BarrysTireTech.com
fj12ryder
Platte City, MO
Posted: 06/04/22 06:19am Link  |  Quote  |  Print  |  Notify Moderator
amxpress wrote:
I believe you meant Goodyear Endurance tires as their Adavantage line is designed for automobiles, not trailers. Maxxis M8008 are also a good choice.
Whatever non-Chinese tire you choose, be sure to have them balanced.
If you have the tires balanced, make sure the place knows they came off a trailer, and need to be balanced lug-centric, and not hub-centric. Many tire places cannot do a lug-centric balance, and a hub-centric balance could, and probably would, make things worse.
Howard and Peggy
"Don't Panic"
dedmiston
Coast to Coast
Administrator
Posted: 06/04/22 06:20am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
dedmiston wrote:
I've driven coast-to-coast twice already this year and the roads in Florida are some of the best I've seen.
My guess would be a road hazard like someone mentioned previously. Not much you can do about that but just drive defensively. It's kind of a "why do bad things happen to good people" thing. Eventually it's your turn.
Good for you for driving safely and keeping it under control.
Best of luck to you.
Wouldn't a road hazard get the truck tires too?
Not necessarily. I've only had one blowout on my current rig, but I've had plenty of nails and screws. The score is probably 6-1 of nails and screws in my trailer tires compared to my truck.
When you consider curves and lane changes, the trailer doesn't really track that closely behind the truck.
I think the real difference though is the multiple axles.
When I hit a nail or a screw with my truck tires, it throws the piece up and it goes who-knows-where. But when I hit that same debris with my front tire on my triple axle, it gets airborne and now I've got two more shots at hitting that thing that's pointed up instead of laying flat on the ground.
It's all theoretical since I can't see any of this happening, but my punctures are usually on my middle or rear tires, so the theory holds up pretty well.
Tangent:
One of my neighbors texted me a photo from his memories the other day. It was a gorgeous sunset out in the middle of the desert about 25-30 miles from camp with our off-road group.
His message was to look at the gorgeous sunset and wasn't that a fun ride. I looked closer at the photo though and I was down in the corner on my knees plugging a tire on our car. His "gorgeous sunset" moment was my "field repair" moment. Very different perspectives.
I remember his comment at the time. "Hey man, I didn't know you knew how to plug a tire."
"Yeah man, I didn't think you knew how to walk thirty miles, so I figured my way was easier."
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
JIMNLIN
Oklahoma
Posted: 06/04/22 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Not all ST tires made in china are china bombs. Most brands in load C/D/E are though. Those are the ones that work better on a lawn service trailers that gets pulled around town...or utility trailers that sit most of the time....boat trailers that make local short runs to the local fishin spot...neither see very little if any long all day runs on the highway carrying a load like many rv trailers operate.
I pull a lot of miles per year on my rv trailers (8k-10K) with 5.2k-6k axles. I use LT tires so just like my trucks I don't have any tire issues at any speeds.
On my flatdeck trailers with 3500-4000 lb axles I use P tires and like the P tires on the wifes 1500 chevy they also have no issues.
OP didn't mention what size/load range is on his new trailer so not much in the way of a good tire recommendations.
But the OP is right about ST tires just letting go. BTDT years ago even when all ST tires were made in the USA.
Road hazards ?? Tires on our tow vehicle run over the same potholes/obstacles as the tires on the trailer. Doesn't take much to see what tire types make it and which ones don't.
Martyn
Panama City Beach, FL USA
Posted: 06/04/22 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Trailer King tires are about the worst tire out there. On my new Cougar one blew after only 50 miles. They have extremely thin walls and are thus very susceptible to blowing. I replaced all four of mine with Carlisles within a week of purchase. Have now driven thousands of miles with no issue. If you research Trailer King tires you will find many horror stories. IMHO It's actually quite interesting that the OP's tires lasted as long as they did.
2020 Keystone Cougar Half-Ton 27SGS;
2019 Dodge Ram 2500 QC 4x4 6.4 Hemi BigHorn;
DEMCO Autoslide; 2 Honda EU2000i's;
Our Website
Posted: 06/04/22 09:29am Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
Reading on the war in Ukraine (NO this is not political)
One of the reasons given for why Russia is not doing nearly as well as one might expect with big mighty Russia attempting to squash tiny little Ukraine.
Chinese Tires. (I told you it was not political)
Now THAT is funny!!!
Edit, and Dedmiston’s last post too. I can picture exactly what you’re saying!
* This post was edited 06/04/22 09:36am by Grit dog *
Posted: 06/04/22 09:44am Link  |  Quote  |  Print  |  Notify Moderator
@solman,
Good luck in getting your rig fixed back up. And thank you for sharing. I been staring at my 5 year old china bomb camper tires thinking, “they made it last year”, trying to decide if I get myself bent over on tires that will literally hold my camper off the ground and nothing more for 360 days a year, to provide the assurance during the few days it does actually move.
Like Dedmiston, aside from a couple wonderful batches of GY Marathins back in the day, I believe I can a tribute most or all flats or blowouts to road hazards. Came home from a little trip up the mountain with my snomachines trailer last winter. 3 tires had steel stuck in them. 2 on the truck, 1 on the trailer, don’t know how I didn’t get a flat. Must’ve hit the remnants of an exploded tire chain just right!
But thanks to your post, your provided the folks here hours of debate and comment and speculation about everything and nothing at all!
Cummins12V98
on the road
Posted: 06/04/22 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Go with the GY ENDURANCE as they have been on the market for over 5 years with ZERO reported non road hazard claims.
First thing the naysayers said "they have not been on the market long enough". Then with years racking up they gave up on that claim and the only thing they can say now is "the tread is too thin". Well I am here to tell you I have plenty of tread left at 20k on mine that are dated 2517. They get driven nearly every day on my heavy Boat trailer at 70mph during the 6 Summer months. They are dropped into Salt water twice each trip. They get the heck "scrubbed out of them at the rough gravel parking lot/ and launch.
OH they also set on a concrete floor for 6 month at a time every winter.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
larry barnhart
wenatchee. wa usa
Posted: 06/04/22 10:38am Link  |  Quote  |  Print  |  Notify Moderator
We always had plywood under our trailer tires when it is parked. last trailer also expect for the last few days we had it in our driveway. Our chev will be on plywood for the winter also.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Page of 5
