RV.Net Open Roads Forum: Tow Vehicles: Sumo Springs on 2022 F350 SRW
Search only in Tow Vehicles
 > Sumo Springs on 2022 F350 SRW
IdaD
Idaho
Posted: 06/06/22 11:54am Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
- Timbrens aren't progressive, so running empty, they tend to be harsh when they engage (not as bad a bump stop).
I haven't noticed any ride quality difference on my 2015 2500 with Timbrens. I put them on when the truck was pretty much new so 7 years and almost 90k miles, and they're holding up fine. I probably have an inch or so between the Timbren and axle when empty.
2015 Cummins Ram 4wd CC/SB
2112
Posted: 06/06/22 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
Timbrens aren't progressive,.....
They are progressive. I have owned a pair for 16 years without issue.
Here's a comprehensive video comparing Sumos an Timbrens https://youtu.be/gGbTbSisBd4
2013 KZ Durango 2857
Cummins12V98
on the road
Posted: 06/06/22 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
Cummins12V98 wrote:
Why not add airbags and set to have the truck run level. Bilstien's are another good add along with proper tire pressure based on load.
They are a 3-4 times the upfront cost and they require maintenance and adjustment.
And before you say it...Installed incorrectly, they won't last long either.
HMMMMM, never had an issue and never heard of any maintenance on air bags.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
MNRon
Tennessee
Posted: 06/06/22 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
Interim Update
Spent a while on the phone with Sumo Tech Services Mgr - great guy, and fabulous support!
He commented that the Sumo (or bump stop etc) does not travel in a straight line relative to the lower perch stop, which is rounded and angled to intersect accounting for this. He took my installation specifics, weights, etc and believes that all is correct but that potentially a bump or something temporary ‘overloaded’ the Sumo causing it to swish sideways in attempt to relieve this and sliding off of the perch; once off it no longer functions properly and was tore apart with further bumps.
He wanted further specifics (which I sent tonight), but called me back to say that he’d already set replacement parts aside (including platforms to prevent a similar problem in the future) awaiting an address to intersect my travel. He also commented that leaving a little bit larger initial unloaded gap could also minimize this issue.
Can’t say enough good about Sumospring responsiveness so far!! Hope to get this resolved within the next few days and then a couple thousand miles traveling the Rockies over the next 4-5 weeks should give the resolution a good test. Thanks for all the replies and information. Hope to report back good news in a month [emoticon]
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
MNRon
Tennessee
Posted: 07/18/22 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
* FINAL UPDATE *
As mentioned, the Sumosprings customer service was fabulous! Not only did they send me new Sumosprings, but also sent landing platforms to ensure that I wouldn’t have the same issue as I initially experienced. Even more, because I’d mentioned that I noticed more ‘drift’ in the F350 steering as compared to my prior Duramax3500, they sent me some additional bump stops to engage the overload springs earlier to help with handling; FREE!
After installing everything (an hour and a half because I did it in campground) everything is working great. I’ve traveled ~2K miles in the Rockies and high plains (including a couple days in strong, gusty, cross winds) and the loaded handling is wonderful. Solved the squat issue, as well as significantly reduced the steering drift I’d noticed. Additionally, I’ve put on another 2K miles unloaded and am equally happy with unloaded performance. The unloaded gap means that unloaded performance is identical to pre-Sumosprings unless I hit larger bumps which then start to engage. I do notice large bumps can cause the overload stops to make a noise once in a while. Bottom line though, I’m happy to trade that for the superior loaded performance.
End result - very happy with Sumosprings, even happier with their customer service!!
fj12ryder
Platte City, MO
Posted: 07/19/22 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a stand up company.
Howard and Peggy
"Don't Panic"
TravelinDog
Nevada
Posted: 07/19/22 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Glad you got the issue resolved. Nice to see a company stand behind its product.
Just say no to the payload police ">
Posted: 07/21/22 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
A basic set of 5klb bags is around 10% more than a set of sumos. Giver take.
I suppose they do require adjustment. IE adding or removing air.
But you’re comparing 2 different products that perform a similar function.
I never have had airbag maintenance on any of my to do lists….Had one fail at 15+ years old. But I’ve never used sumos or Timbrens for 15 years to compare whether they last longer.
Bottom line, OP got too soft of Sumos, or relied on them too heavily or improper fit/install. Or combination thereof.
2017 Heartland Torque T29
Huntindog
Phoenix AZ
Posted: 07/21/22 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
I like the flexability of airbags. Not so much for the weight capacity, but being able to raise and lower the nose of the 5ver. My first trip out with it there was a small berm going into our campsite. The leveling jacks would not clear it. We ended up doing a lot of shovel work to get it done. With the airbags and on board bluetooth pump, we can easily get past such an obstacle without breaking a sweat.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
Thermoguy
Graham, WA
Posted: 07/24/22 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
I'm impressed that you have driven 4K miles in just over a month...
