RV.Net Open Roads Forum: Tech Issues: Dometic Air Brisk 2 13.5 starting issues
 > Dometic Air Brisk 2 13.5 starting issues
ESDA
Michigan
Posted: 06/04/22 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Dometic Brisk II 13.5 air conditioner that is about a year and a half old. It runs great, however fairly regularly after it reaches the set temp on the thermostat it shuts down as normal, however it does not start up again as the temp in the trailer rises. If I shut the thermostat off for 10-15 seconds than reset it to the a/c it will start up and run fine. I have replaced the thermostat, but it does the same thing. Does anyone have any ideas?
dougrainer
Carrolton, Texas
Posted: 06/05/22 10:47am Link  |  Quote  |  Print  |  Notify Moderator
from your previous almost EXACT problem-----------REPLACE the Freeze sensor. Doug
jdc1
Rescue, Ca
Posted: 06/05/22 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Probably the starter capacitor.
https://www.youtube.com/watch?v=PBoOx8YzD_s
ESDA
Michigan
Posted: 06/05/22 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
The a/c has worked normal all day today, however just now I checked the thermostat, it is set to run at 72, but it is showing the temperature of the trailer is 78. I shut the thermostat off for about 20 seconds and then turned it back to air. The a/c started right up.
