ernie1
Sacramento,California,USA
Michael: I'm assuming you are going to be operating your food vehicle in California. If that's the case, your water heater setup will not suffice. Firstly, you do indeed need hot water for hand washing in addition to washing all your cooking and food prep utensil. Also, you only need two sinks for washing utensils and a separate sink for hand washing. What you need is 120 degreeF water for those sinks. If you have a source of potable water that can feed water to your vehicle that would be a good start. From that point, you have to decide what kind of water heater you'll need. To further clarify the sink requirement, only if you have what is called" multiuse utensils" do you need 3 sinks. Multiuse utensils are generally utensils that are offered to the public to use while dining and need to be sanitized afterwards. Think plates, knives, forks, spoons etc. Throwaway plastic and paper utensils are called "single service" and, being throwaway, do not have to be sanitized.
MichaelCO
Buena Vista
ernie1, we are in Colorado, not California. I guess I will have to find out more detail on rules in Colorado.
ernie1
Yes that would be wise although you'll find that code requirements are not much different. California tends to have the more rigid standards. Good luck.
tiptoptune
Colorado
From a RVer that lives and camps alot for 20 years in Colorado at 10,000 feet - just replaced a 2000 camper that the 6 gallon propane water heater worked fine for years. Think it was a Suburban brand. Recently got a 2023 camper with a Dometic 6 gallon water heater and it will not stay lit above 7,500 feet. It will if i open the exterior cover over it to give it more air. Called Dometic and they pretty much told me now fix for that high of altitude. I thinking of adding another louver on my door to add more air. Sucks that we let mfgs. get away with building stuff that does not work. I was told they typically see more issues with the furnace, however mine works at 10,000. My 2 cents and sorry no help on your exact question.
2023 Bigfoot 2500 10.4 TC on 2000 3500 dually duramax
Previous - Bigfoot 10.11 TC, lance TC, King Of Road 5th.
CharlesinGA
South of Atlanta, Georgia
TANK TYPE RV water heaters are known to provide stupid hot water, well over 130 degrees. Get a 10 or 12 gallon Dometic or Suburban water heater, you will be assured of having the hot water you need and they recover rather quickly too.
Continuous or instant water heaters are marginal at best. Everyone in any forum I have seen says they regretted ordering or installing a instant unit and some even switched back to a tank unit. It takes a lot of propane to make a fire big enough to heat water that hot with it flowing thru.
https://parts.unitedrv.com/collections/w........s-electric-water-heater-wh-10gea-95001sp
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
