RV.Net Open Roads Forum: Tow Vehicles: thoughts on Ecoboost
Search only in Tow Vehicles
 > thoughts on Ecoboost
huskyfan68
usa
Posted: 06/06/22 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Having too many issues with the 09 F150- The 5.4 that year is proving to be to problematic. I borrowed a friends 3.5L Ecoboost to pull my 5000lb trailer and it pulled with little effort. Looking for feedback on dependablity
MitchF150
Puyallup, WA
Posted: 06/06/22 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Been towing with my 13 F150 Ecoboost since new. First with the old #5000 TT I used to tow with the 97 F150 with the 5.4. Different 5.4 than in your 09 however.. You could not give me a truck with the 5.4 3v in it... Garbage IMO..
Anyway, Moved up to a #7000 TT in 2019 and have not looked back.. I did have to switch to 92 octane fuel for the Eco however to take advantage of all of it's potential.. Which, BTW, has proven to me anyway, that it does make a difference... [emoticon]
You do gotta watch how much 'boost' you give it on the grades.. Those turbos will heat up the motor pretty quick. Also, don't lug the engine either thinking you are saving gas by lowering your rpms while towing... Don't work that way.. Yes, your rpms are lower, but your boost is higher, so it just dumps more fuel in it, and also creates more heat at the same time.
Keep the rpms around the 2200 range while on the flats and it'll actually give you a bit better mpgs than running lower rpms..
I'll give it a 'thumbs up' with the disclaimer that you have to know your rig and just not put it in gear and stab the go pedal.. [emoticon]
Good luck! Mitch
bgum
South Louisiana
Posted: 06/06/22 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Anything that needs that much attention belongs in someone else's garage.
Posted: 06/06/22 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Not a ford guy but 2 thumbs up for the eco boost.
Just do a little research. First cpl years had an intercooler thing going on. And some/all have cam phaser ? issues. But GM and Ram have issues too.
Eco boost is generally good though. Or they would t be largely the same engine 10 years later.
BurbMan
Indianapolis, IN
Posted: 06/06/22 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
We leased a 2018 Explorer Sport with the 3.5 EB and only towing experience was a double axle U haul cargo trailer that was probably 3k lbs when loaded up. Power was awesome, I could tow that trailer at 70 mph all day long up and down hills....except for the 7 mpg and 18 gal tank that had us stopping for fuel every 2 hours. Could almost set your watch by the fuel stops. We put about 20k miles on the Explorer before the lease was up but zero problems.
This motor has been out for several years and don't hear many if any issues with the longevity on the internals etc. Gotta run premium gas though. I think for a 7K trailer it really comes down to how far and how often you tow, I don't think there's any question it will get the job done reliably.
Southern California :(
Posted: 06/06/22 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have a Ford 3.5 Ecoboost but a number of my friends do. They are happy.
IdaD
Idaho
Posted: 06/06/22 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
My sister has a couple, one in an F150 and one in an Expedition. They have about a 6000-7000 lb loaded travel trailer. One of them, and I think it's the F150, has trouble overheating when towing on long grades in warm weather. I don't know if there's something wrong with it or they aren't managing it properly per a couple of posts up. Aside from that I think they've been pretty happy with them. The only other thing I've consistently heard about Ecoboosts is that the fuel economy is terrible when towing.
2015 Cummins Ram 4wd CC/SB
Mike134
Elgin, IL
Posted: 06/06/22 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have 48,000 on mine with no issues.
As someone above mentioned keep the RPMs around 2200 gives the best gas milage when towing. 9-11 MPG for me depending on wind direction.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
BarabooBob
Baraboo, WI
Posted: 06/06/22 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have 229,000 miles on mine. At 185,000 I had to have the timing equipment replaced. At 215,000 miles I had an exhaust manifold warp. Not cheap repairs but nothing that busted the bank either. I only tow about 3500 pounds but have never had the engine heating up and I have towed over many 11,000 ft passes (most of the major ones) including I70, Trial Ridge Road, Beartooth, and 14A going both directions. We have put 50,000 miles of towing on the truck. I d3etermine my tranny gear by watching the tranny temp and shift if it gets above 200 degrees. I have never run out of power.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
MitchF150
Puyallup, WA
Posted: 06/06/22 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, and that's why mine is in my garage.. [emoticon]
I thought towing something heavy always needed some extra 'attention' while doing it?? [emoticon]
Mitch
