RV.Net Open Roads Forum: Truck Campers: A Little Help With Weights
 > A Little Help With Weights
Page of 7
wjlapier
Washington
Posted: 06/06/22 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
We purchased a Host Everest recently. We figured we would need a newer duality so we traded in our 2015 GMC short bed 3500 for a 2019 Chevy dually. Here are some numbers I have and am hoping for clarification for my piece of mind haha…
GVWR—13000
Curb Weight full tank—8400 ( Just weighed today after fill up )
GM Truck Camper Rating ( sticker in glovebox )—3900
Host Everest As Equipped—4350 ( Host Sticker )
Am I missing anything?
I assume we gain back some GVWR with no passengers in rear seat.
We won’t travel with water in the camper until we are close to our camping destination.
Question is, what is our true payload weight less mine and my wife’s weight. And her duffle bag lol! For now we are carefully considering our usual camping gear while we load up.
Thanks a lot.
2019 Chevrolet 3500HD LTZ DRW
2023 Host Everest
Geo*Boy
Unknown
Posted: 06/06/22 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Once you put batteries, propane, all your household goods for cooking and eating/drinking, clothes, basic supplies, you will be well over your trucks payload.
mike/kellie
northern calif.
Posted: 06/06/22 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
I think your camper is going to push +/- 5500 lbs ready to travel. Payload is indeed published and most people with the bigger campers identify the components (axle, wheels, tires etc) as well as test drive the unit to better gauge if suspension upgrades might be needed.
2015 Host Mammoth triple slide w/ TorkLift Fastguns
2015 Ram 5500 SLT cab & chassis with Douglass 9' utility body
wjlapier
Washington
Posted: 06/06/22 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
I have stable loads upper and lower only and the ride home was smooth and without any issues. Interestingly, I found out the camper still had the half tank of water the shop put in to do the walk through.
JIMNLIN
Oklahoma
Posted: 06/06/22 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
What was your trucks separate axle weights ?
GM gives that model 3500 drw a 9375 rawr I believe. Lets say your empty truck rear axle weight was 3500 lbs. Simply subtract that number from 9375 = 5875 lbs for a in the bed payload....... rawr = the lessor of tires/wheel/rear spring pack or the axle assy.
Most newer gen high gvwr LDTs wheels or the rear spring pack are the weak link. GM uses the 11.5" AAM rear axle which is rated around 10800 lbs....4 tires at dual rating = 11k-12k lbs.
toddb
az
Posted: 06/06/22 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
Load it up and weight it. My af says 4240, full fuel and water tips 13300, 8800 on the rear.
JimK-NY
NY
Posted: 06/07/22 05:36am Link  |  Quote  |  Print  |  Notify Moderator
You bought a big, heavy camper. Don't diminish your enjoyment by worrying about the load or trying to get by with minimum stuff.
Load your camper with stuff you want to take, then check the weight on each axle or better yet each wheel. The biggest concern is to fall short of the tire load ratings. If that is OK check out the ride. At the worst you might need to consider some suspension enhancements.
When it comes to loading the camper, most of us expect to add at least 1000#. I used to full time and even now take long trips so my load is even more. A thousand plus pounds sounds like a lot until you really look at what is involved: clothing/boots, food/drink, toiletries, towels, first aid kit, cleaning implements and materials, extension cords, tools, hardware and misc supplies, BBW grill/fuel, generator/fuel, air compressor, leveling blocks, backpacks and hiking gear, lawn chairs, bedding, hobby stuff (cameras, laptops, electronics, chargers, batteries, books...). I added a solar panel and upgraded my battery bank. That added at least another hundred pounds. I probably also have an extra hundred pounds of clothing. I leave the camper packed and ready to go with 3 seasons of clothing including jackets, raingear, lots of hats and about 30 days of underwear, socks, and T shirts, extra blankets. The extra means avoiding the laundromat for weeks on long trips. We also carry some canned goods and staples to get by when grocery stores are few and far between. We are way over the extra 1000# largely due to the generator, solar panels, and battery bank upgrade. Oops, forgot another major upgrade. We replaced the nasty original mattress with a nice, but heavy, 8" dual layer, foam mattress.
valhalla360
No paticular place.
Posted: 06/07/22 06:22am Link  |  Quote  |  Print  |  Notify Moderator
If your goal is to be within manufacturer weight limits, you are already over with an empty camper.
If you choose to ignore the manufacturer weight limits, expect to be over by 1500lb or so.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
notsobigjoe
southeast
Posted: 06/07/22 06:36am Link  |  Quote  |  Print  |  Notify Moderator
My Lance 1181 pushes 5500 when loaded I bet he'd be closer to 6000. Big camper!
notsobigjoe
southeast
Posted: 06/07/22 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Ditto's to all. OP have a good time, It's a beautiful unit. I have never run under 1500 over weight and on a longer trip like Jim says probably closer to 2000. Tires and suspension is where you beef it up. You can also get oversized brake pads from a speed shop like I have on mine. Good luck sir!
Page of 7
