Bedlam
PNW
My Mammoth is 6000 lbs when filled and loaded. If you do not plan to tow anything with tongue weight, you will be fine. If you tow a heavy trailer behind your camper, you will be pushing rear axle limits.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD
mkirsch
Rochester, NY
Don't look at GVWR. Look at the individual axle ratings and weights.
Your truck should have a 6000lb+ payload rating that way.
Yes, you will be over GVWR, but as long as you don't exceed axle or even more importantly, tire ratings, you will be safe.
Add suspension enhancements as you find necessary.
MFL
Midwest
^^Agree with above. It seems most, that post about wt concerns, on the TC forum, have a better understanding of what is important!
Jerry
wjlapier wrote: I have stable loads upper and lower only and the ride home was smooth and without any issues. Interestingly, I found out the camper still had the half tank of water the shop put in to do the walk through.
Stop right here and quit asking about the weight, unless you want to become paranoid and freak out about your truck and camper.
It is 1000% fine and if you want to know the “real” payload, do some reading. This topic comes up every other day on here (figuratively).
And let’s face it, you’re too late. If this really was a concern it should have been before buying. Now , all you’re doin is feeding the weight trolls on here, lol!
Go enjoy your camper and don’t worry about it.
toddb wrote: Load it up and weight it. My af says 4240, full fuel and water tips 13300, 8800 on the rear.
Your empty truck has 4500lbs on the rear axle?
Full service bed or bad math?
Atchafalaya_man
Lafayette, Louisiana
Add 1000 to 1500 pounds to any published or sticker weight you can find and you'll be in the ballpark of what a scale will tell you it weighs.
mkirsch
Rochester, NY
Grit dog wrote: toddb wrote: Load it up and weight it. My af says 4240, full fuel and water tips 13300, 8800 on the rear.
4240 is the "dry weight" listed on the placard.
"Full fuel and water" meaning the camper is loaded and ready to camp, not "dry." So it's heavier.
Truck's not 4500lbs empty. Maybe 3500. Camper is around 5200 loaded and ready to camp.
mkirsch wrote: Grit dog wrote: toddb wrote: Load it up and weight it. My af says 4240, full fuel and water tips 13300, 8800 on the rear.
You got my point. OP got the runs and ran away from the thread...
Edit, sorry OP, I confused you with the guy above who posted his weights from a different setup for whatever reason.
edited 06/09/22 01:23pm by Grit dog *
wjlapier
Washington
Still here.
2019 Chevrolet 3500HD LTZ DRW
2023 Host Everest
mkirsch
Rochester, NY
Grit dog wrote: You got my point. OP got the runs and ran away from the thread...
I usually do. Don't always agree with it.
For those that question the contributor's reason for posting his weight, it is to demonstrate that these campers can come out significantly heavier than factory advertised weight.
Ultimately the OP is fine. What he is doing is something commonly done. Might need some suspension helpers to make it not look so saggy, but otherwise, load up and hit the road.
