RV.Net Open Roads Forum: Tech Issues: Self adhesive shower grab bar needed
 > Self adhesive shower grab bar needed
Gdetrailer
PA
Posted: 06/08/22 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
bighatnohorse wrote:
jdc1 wrote:
Why not remove the paneling on the opposite wall and put real wood backing where you want the grab bar? Safest long-term thing to do, IMO.
Thats worth looking into.
For a person with balance issues ANYTHING besides a smooth wall would help.
This one: Adhesive Grab Bar is rated at something like 250 pounds.
(the suction cup type are rated at 5 pounds)
Did you read the reviews from your link?
Here's just the first page of reviews..
"We've been using this grab bar for years but twice in the past 6 months I've had to replace the mounting hardware. I follow the directions exactly so not sure why one side or the other comes loose.
I installed a shower bar and a short while later it detached
I called Customer Service, they were extremely accommodating and understanding.
In discussion with them it was apparent that I did not prep the wall appropriately
They sent out a new mounting kit
I followed the directions exactly
The installation instructions were very easy to read and understand. As long as you follow the provided instructions, installation is very simple. The key to a successful installation, is the surface prep. I allowed the adhesive to cure for 48 hours before installing the bars, and their performance has exceeded my expectations.
However, 60 days later, the 36-inch bar fell off on one end. Innovative Products sent out a new Mounting Hardware Set, under warranty. Upon examination of the failed installation photos, it was determined that the wall was not perfectly flat / on the same plane.
After being installed for about 3 weeks, one end of my 36" grab bar failed.
One applies the mastic through a hole in baseplate and 3 weep holes let you know mastic is flowing. To be sure of good adhesion, let plenty of mastic flow to insure a tight bond. Also, make sure the surface has been thoroughly cleaned with alcohol/ acetone. Something went wrong for me but the company provided excellent support and I had a very successful installation."
Not trying to be a jerk, but pretty much every review say's something to the effect of how great the customer service is, some list the failures for the need to contact customer service, some do not.
No matter just how great the customer service may be, it will be well after the fact when the device you installed that was supposed to keep one safe failed unexpectedly.
Not to mention, I highly doubt any of those installs were in a RV (moving, flexing home on the road) with paper thin RV materials.
Heck, I have had car rear view mirror mounts fall right off the window glass more than once. I wouldn't wish to bet my life on anything stuck together solely with adhesives.
Can't beat mechanical fasteners.
OPs best way is to find a way to get sufficient supporting wood behind the surround and drill and screw right on through the surround. Sealants can be applied to provide water tight seal.
OP may need to get creative and find a spot they might be able to remove the wallboard to gain access to the back side of the surround.
Posted: 06/08/22 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Textured and self adhesive and camper construction do not go together.
If you need a handle, it needs to be solid.
* This post was edited 06/08/22 04:33pm by an administrator/moderator *
2017 Heartland Torque T29
bighatnohorse
Gig Harbor - Cave Creek
Posted: 06/09/22 08:40am Link  |  Quote  |  Print  |  Notify Moderator
The show is a tiny stand-up-in shower and one side is a flimsy curtain.
One could fall through the curtain, but not actually "fall down" inside the shower.
I did read the reviews on the link.
My hope was someone on this forum already had solved this problem.
JimK-NY
NY
Posted: 06/09/22 10:33am Link  |  Quote  |  Print  |  Notify Moderator
My shower at home consists of a tub with tile on three sides and a "flimsy curtain" on one side. There is no grab bar nor have I had to have one. Again, what is the "problem"?
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 06/09/22 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
The only rational way to accomplish a safe surface would need a fascia plate of stainless steel or aluminum that would bankrupt any budget. Exlanation: An outside plate beneath the grab bar that would distribute the pull over a couple of square feet.
bighatnohorse
Posted: 06/09/22 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
One person has a disability with a sense of balance of about 10-percent.
JimK-NY
NY
Posted: 06/09/22 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
That sounds like something more than a grab bar is needed. Perhaps a stool to sit on during the showering. Maybe something like a stainless steel walker to use in the shower. A sturdy door instead of a flimsy curtain. The door might even hold a grab bar. I hope you also have a good, non skid flooring surface or at least a shower mat.
10% balance sounds really bad--like the need to sit down to take a shower.
bighatnohorse
Posted: 06/10/22 07:10am Link  |  Quote  |  Print  |  Notify Moderator
JimK-NY
It might be better to ditch the truck camper and get a class-C or something with a more appropriate shower.
Posted: 06/10/22 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Idk how, but you would need to find some structure (a wall stud) to mount to. And even at that, I wouldn't be super comfortable with, moreso, sinking screws into an already semi fragile structure for this purpose.
Sorry to hear of the issue, but I can't think of a good solution here. Too many constraints from space to structure, IMO.
