RV.Net Open Roads Forum: Fifth-Wheels: Tonneau Covers
 > Tonneau Covers
Lantley
Ellicott City, Maryland
Posted: 06/09/22 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
ford truck guy wrote:
padredw wrote:
What I do not like about the back flip is the fact that it blocks the rear window when opened all the way
Yes it does, but have never had need to drive with it in that position. The hitch works just fine with the cover in the next to last position. The cover snugs down and tows fine in that position; also allows covered storage under that front panel.
Thank You for the explanation....
Correct for towing a fiver next to last position works.
However if you truly need to drive with cover in last position its doable. Having it in window blocking position may still be a better option than removing the cover.
Removing the cover totally is easy enough, but leaving it in last position is still easier than totally removing cover.
Blocking the rear window is not the end of the world.
No worse than towing a fiver where you can't see out the rear window past the trailer.
Once you grasp how the Bak Flip operates/folds you realize it gives you options that the other covers don't.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
CabinetmakerII
Idaho
Posted: 06/12/22 05:59am Link  |  Quote  |  Print  |  Notify Moderator
on my 2nd Back Flip. Wouldn't have anything else.
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2006 700 Arctic Cat ATV (X2)(Retired)
2014 Kawasaki Tyrex 4LE Side by Side
 > Tonneau Covers
