RV.Net Open Roads Forum: General RVing Issues: Need guidance on best roof trailers
 > Need guidance on best roof trailers
landingzone
Western NY
Posted: 06/07/22 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
I will soon be in the market for a used camper for a permanent vacation site. It will likely be 5-10 yrs. old and 30ish ft. long with slides. Are there any makes/models which have seemed to stand above the rest for not leaking? What should I look out for? Is it reasonable to find a trailer of this age that won't need roof repair fairly soon? Thanks.
BurbMan
Indianapolis, IN
Posted: 06/07/22 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Most all RVs have rubber roofs and are sealed around the edges and the penetration points like vents, etc. How well the trailer was maintained has more of an effect on leak resistance than a particular brand. I would think if you are doing a seasonal site especially in upstate NY you would want to build something like this:
Southern California :(
Posted: 06/07/22 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Roof maintenance is the key. Check those records closely on a used RV and do maintenance at least twice a year.
theoldwizard1
SE MI
Posted: 06/07/22 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
The longest lasting roofing material is aluminum. Still not perfect as there will be seams that are potential leak points.
Any trailer that is 10 years old and not had EXCELLENT care (wash and treat with UV resistant spray) is going to need a new roof (NOT A RECOAT) soon.
A carport type covering is your best solution.
WNYBob
Tonawanda, NY
Posted: 06/07/22 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
We have a TT with a fiberglas roof, made the same way as the walls. It is a 2014 and shows no signs of deterioration.
PS it is a Evergreen Ascend 231RKB, which is regretfully no longer made.
Skibane
San Antonio, TX
Posted: 06/07/22 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Molded fiberglass is right up there, too.
Most of the GMC motorhomes built in the 1970's still have their original roofs. A lot of them still look brand-new.
theoldwizard1
SE MI
Posted: 06/07/22 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
I forgot about that because there are so few RVs that have that.
TPO, especially commercial grade (thickness) is an excellent choice for an OEM roof.
Camper445
Sticks
Posted: 06/08/22 03:16am Link  |  Quote  |  Print  |  Notify Moderator
For the last 8-10 years the vast majority of travel trailers and 5th wheels have Alpha Systems Superflex roofing, basically a thin PVC, think thin pool Liner. Forest River and Thor use it on most if not all of their brands and it has been on every Grand Design product ever made. That's about 90%+ of the towable market. Alpha systems entered into an exclusive distribution agreement with Lippert in 2020, that should tell you its the cheapest material available.
landingzone
Western NY
Posted: 06/08/22 06:37am Link  |  Quote  |  Print  |  Notify Moderator
What is TPO?
landingzone
Western NY
Posted: 06/08/22 06:39am Link  |  Quote  |  Print  |  Notify Moderator
What brands use aluminum roofs?
Thanks.
