RV.Net Open Roads Forum: Technology Corner: Help with Winegard
 > Help with Winegard
texasfire
Merkel
Posted: 06/07/22 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
We recently bought a Crusader fifth wheel that had the Winegard installed, unfortunately there are no instructions. I tried calling them and sat on hold for 30 minutes, tried emailing them but have gotten no response. The only paperwork we have with the trailer talks about turning the antenna manually from the inside but there is no handle to turn like in our old trailer. Any help would be appreciated.
rk911
DuPage County
Posted: 06/07/22 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
winegard what? sat? OTA antenna? motorized? a model name/number would help us.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Posted: 06/07/22 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Winegard makes several antennas
one, well several, are of a design we call "the Batwing antennas" These have ahandle to turn and the Sensar IV is one of if not the best RV OTA antenna
The ROadstar looks like a flying saucer.. The most common one is an "omin"direcitonal meaning it works equally bad in all directions.
There is another flying saucer that is direcitonal or so I'm told.. I saw another company's version of it. Never seen the winegard.
Then there are satellite TV antennas. Again multiple models.
We really need to know which one you have.
texasfire
Merkel
Posted: 06/07/22 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
According to the paperwork that I do have its an Air 360+ long range omnidirectional HDTV antenna. Brown round plastic bubble on the roof. I also have a small button mounted in a compartment that stays red, if you hold it long enough it will flash but that's about it.
enblethen
Moses Lake, WA
Posted: 06/07/22 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Manual
No crank!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
craig7h
Branson MO area
Posted: 06/08/22 03:06am Link  |  Quote  |  Print  |  Notify Moderator
google is really your friend in the RV world.
https://winegard.com/air-360-hdtv-antenna/
at the bottom is link to owners manual
Itasca Meridian SE 36g
Road Master Tow Dolly
Posted: 06/08/22 05:01am Link  |  Quote  |  Print  |  Notify Moderator
Omnidirectional antennas do not have the crank or knob that the Batwing has.
They also do not have the range (Senistivity) the Batwing has
So the reason you can not find the crank and knob.. There isn't any.
Cptnvideo
Arizona - most of the time
Posted: 06/11/22 11:44am Link  |  Quote  |  Print  |  Notify Moderator
The red light indicates that the amplifier (built in) is not powered. The light will be green when the amp is powered.
BTW, amplifier not powered is worse (gain wise) than no amplifier at all.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, 3kw inverter/charger, 3 206AH LiFePo4 batteries
