RV.Net Open Roads Forum: Tow Vehicles: Will a 3/4 ton do
Search only in Tow Vehicles
 > Will a 3/4 ton do
Page of 15
rarin'2go
Medway, OH, USA
Posted: 06/07/22 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have an rv that is at the 14000 GVWR. I need a new tow vehicle and was wondering if a 2500 or 3/4 ton truck would safely tow this. I would appreciate your knowledgeable input on this. Would this being a 5th wheel make a difference?
Thanks
* This post was edited 06/07/22 07:30pm by rarin'2go *
Mike
Cambria, California area
Posted: 06/07/22 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
For the few hundred that a one ton is priced over a 3/4, get the one ton.
BB_TX
McKinney, Texas
Posted: 06/07/22 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Will it do? Yes. Many people do it. But you will most likely be over the payload rating of the 3/4 ton (250/2500). Go for a 1 ton (350/3500).
MNRon
Tennessee
Posted: 06/07/22 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
You’ll run out of rear wheel capacity to carry the pin weight. 1Ts don’t cost much more and add additional rear suspension, I’d recommend giving them a serious look. Even with a 1T you won’t have a lot of excess RAWR.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
MFL
Midwest
Posted: 06/07/22 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
If you already had the late model 2500, Id say it will work. Since you are going to purchase a new truck, it just makes more sense to go with a 35 series truck.
Jerry
Lantley
Ellicott City, Maryland
Posted: 06/07/22 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
This^^^
Don't knowingly start out with an underated truck.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
S Davis
Western WA
Posted: 06/07/22 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you like messing with your vehicles go 3/4 ton, I towed a 14,000lb gooseneck with a 2013 2500HD and had to add helper springs, upgraded shocks and upgraded tires. My pin weight was over 3000lbs.
thomas201
Eastern Panhandle WV
Posted: 06/08/22 05:47am Link  |  Quote  |  Print  |  Notify Moderator
What is your pin weight? A 3/4 ton might work, but you are asking the wrong question. The question is, "Do you need a 3/4 ton?". The price difference is small, but I run a 3/4 ton due to homeowners assoc. rules, hammer lanes in MD and NJ, Baltimore-Washington Parkway, blah and blah.
So, a compromise, depending on your needs. If a 3/4 ton will work with your pin weight and you need it, fine. If not, I would get a one ton. With Fords, the camper/snowplow package almost gets you a 1 ton, except on paper.
valhalla360
No paticular place.
Posted: 06/08/22 05:55am Link  |  Quote  |  Print  |  Notify Moderator
At 14k, I'm guessing it's a 5th wheel (not many bumper pulls that heavy).
It may have enough grunt to pull it (or it might not, have to check the specifics).
The problem is it's likely going to have a pin weight on the order of 3000lb (give or take a couple hundred). That counts against the truck payload. Add in other stuff, including passengers in the truck and very good chance you exceed the truck payload.
A 1ton SRW probably will have enough payload but that's getting borderline where I would be considering dually.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
IdaD
Idaho
Posted: 06/08/22 08:16am Link  |  Quote  |  Print  |  Notify Moderator
This guy just nailed the real answer. Some 2500s now come with higher than 10k lb GVWR, and some 3500s come with a 10k lb GVWR. Reality is 2500 vs SRW 3500 generally means nothing in terms of performance or capability.
The real question is 10k lb GVWR or a higher number. Since you're buying new, if the higher number won't cause you any problems go ahead and go that route. It it does such as in the example above, get something with a 10k lb GVWR and you've still functionally got the same truck, maybe at most with adding bags/timbrens.
I don't think you need a dually at 14k lbs if you don't want one, but that's the actual next step up in capability.
2015 Cummins Ram 4wd CC/SB
Page of 15
 > Will a 3/4 ton do
