S Davis
Western WA
Well you don’t have to be real bright to know when you are over tire capacities, but I guess that doesn’t mean much to some.
S Davis wrote: Well you don’t have to be real bright to know when you are over tire capacities, but I guess that doesn’t mean much to some.
You’d be surprised how ill informed or ignorant (both in the true sense and the common connotation) some people are….
I’ve quit being personally surprised long ago though…..
What’s really funny and to share, while protecting the identity of the guilty, is one person, who fits the bill in the above category apparently, got so wound up over their position, or maybe my position which was contrary (and correct btw ) they cussed me out privately!
To that person and those like you, you should take a step back and if something like this thread causes you enough anger or frustration to lash out like you have turrets, then maybe find something else to do, as it’s not healthy for you to participate in this game!
Btw sorry _______. I only try to provide the best info for folks who are asking a question and admittedly aren’t well read. The collateral damage comes with choosing to dis spell the uninformed wrong answers, objectively and with fact, in an effort to steer the person with the honest question in the right direction.
MFL
Midwest
^^Made a great start to my day Grit! That is hilarious! Nice of you to share! I have to say, while you may have been unjustly cussed out in this instance, it only makes up for when you should have been cussed out, and were not! ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Jerry
BenK
SF BayArea
If TV's fell out of the sky from going over ratings like airplanes would, then both the regulatory folks and owner/drivers would think differently...because when a TV is over and breaks or some such...they just roll to a stop on the side of the road
Ditto other types of people movers.
We were in the ski lift business for years (late 60's to early 70's), until lawsuits became outrageous & jury's applied 'current' safety standards to systems built, installed & approved/certified years to decades ago. Resort owners cutting budget & went over the ratings to have components run too hot, towers getting bent (they bypassed the cable derail sensors) and more
spoon059 wrote: BurbMan wrote: You obviously know more about trucks than I do...I do not know for a fact that the axles on a 2500 and 3500 are the same. I only posted the results from my trip to the scale and compared them to the ratings on my truck and the ratings published for a 2500.
I've been contributing to this forum since 2001, 11+ years before you joined, so if anybody is trolling it's you. The OP asked a question about weights and you're trying your best to turn this into an argument.
I believe that ratings are there for a reason, you obviously think they are concocted for political reasons have have no basis in fact. As my Dad used to say, "You're entitled to your opinion, no matter how wrong it may be."
The ratings are for warranty and registration purposes only. You can register a Tacoma to 14,000 lbs and load it up and be perfectly LEGAL, though I doubt it would move very far.
There used to be a larger mechanical difference between 3/4 and 1 ton trucks, but the manufacturers long ago realized that it is much cheaper and easier to put essenentially the same rolling chassis under either truck and change the spring pack and the sticker on the door to meet the DOT requirements for a class 2B truck.
The spring pack is easy to overcome, with helper springs, Timbrens or air bags.
The sticker can simply be ignored and your truck registered for whatever weights you are willing to pay.
My Ram has AAM 11.5" axles in the rear. They are rated to 12,000 lbs by AAM, derated to 7,000 lbs for the 3500 and 6,500 lbs for the 2500 with 18" rims, and 6,000 for the 2500 with 17" rims. Same axle.
The brakes, wheel studs, engine, transmission, rear differential, bumpers, bed, body, tires, radiator, etc are exactly the same. The frame is slightly different, just due to the shock mounts from the 2500 coil to the 3500 leaf. Ram rates the coils at 500 lbs lower than the leaf springs. If that 500 lbs worries someone, they can put bags or Timbrens to make up the difference.
The only reason that truck manufacturers make a 3/4 ton these days is to get into the class 2B market, which only allows a vehicle a max GVWR of 10,000 lbs. You can by a Ford F350 with a 10,000 lbs sticker, does that make it any less capable than an identical F350 with an 11,500 sticker?
-Ben Picture of my rig
MFL wrote: ^^Made a great start to my day Grit! That is hilarious! Nice of you to share! I have to say, while you may have been unjustly cussed out in this instance, it only makes up for when you should have been cussed out, and were not!
Jerry
Lol, yeah you’re probably right!
ford truck guy
Pennsylvania
well......
8 pages of normal RV.Net truck capability arguments and the original OP ( rarin'2go ) was a 1 and done poster on THIS thread.....
I will say that is is/was interesting reading all the response.. what did I learn??
Grit know a TON about trucks and thier capibilities, as do a lot of others..
Cummins HATES IPA
and a Toyota can tow a space shuttle !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
ShinerBock
LVTX
Grit dog wrote: What’s really funny and to share, while protecting the identity of the guilty, is one person, who fits the bill in the above category apparently, got so wound up over their position, or maybe my position which was contrary (and correct btw ![wink [emoticon]](http://www.rv.net/sharedcontent/cfb/images/wink.gif) ) they cussed me out privately!
WOW! I don't think I have ever been that into an online convo to cuss someone out in a PM. Don't get me wrong, I will post massive posts to prove my point(if I have nothing better to do at work) or if I feel I am right about something, but to spend the time to cuss someone out in a PM is on another level.
In regards to the previous comment about tires. I had a family member who bought a 3500 especially for the added payload rating over the 2500 and a week later put large 20" rims and tires that had a load rating about a thousand pounds less than the factory rims and tires which essentially made his truck a 2500 since the tires were the limiting factor.
edited 06/13/22 07:57am by ShinerBock *
2014 Ram 2500 CTD
Highland Ridge Silverstar 378RBS
MFL
Midwest
ShinerBock wrote: Grit dog wrote: What’s really funny and to share, while protecting the identity of the guilty, is one person, who fits the bill in the above category apparently, got so wound up over their position, or maybe my position which was contrary (and correct btw ![wink [emoticon]](http://www.rv.net/sharedcontent/cfb/images/wink.gif) ) they cussed me out privately!
In regards to the previous comment about tires. I had a family member who bought a 3500 specially for the added payload rating and a week later put larger 20" rims and tires that had a load rating about a thousand pounds less than the factory rims and tires which essentially made his truck a 2500 since the tires were the limiting factor.
I believe the person Grit is referring to, did take his advice, and move on. Too bad, but I think he has deeper issues than this forum! I hope he takes care of himself, and becomes a happier/healthier person.
I agree downgrading the tires, makes little sense, when wanting a higher payload. Hope you gave him some helpful advice.
Jerry
Oh, totally. I could mod a dually into a useless POS if I tried hard enough, but I was speaking in general terms, presuming the theoretical "dually" had tires and wheels that didn't make it worse than how it was born.
