RV.Net Open Roads Forum: Tech Issues: Air conditioner stopped working
 > Air conditioner stopped working
Ranger Smith
Wherever the rig is parked
Posted: 06/18/22 04:40am Link  |  Quote  |  Print  |  Notify Moderator
That black capacitor you have will replace the big one with the yellow wire on it. According to the parts list it is a 40 uf capacitor and your 47 to 56 will certainly work.
11. All 1499-5721 Run Capacitor (40 Mfd/370V)
12. All 1499-5461 Fan Capacitor (7.5 Mfd/370V
Where we are now
Amateur Radio Operator N1JS . . . SunSDR2 Dx, Ameritron AL-80 Amp, Icom 7100
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
EMD360
Arvada, CO
Posted: 06/23/22 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
I waited for the OEM run capacitor that came today. I installed it and a new fan capacitor. Now both work on low but not on high. Can’t find anything to explain that. Could the fan motor be broken?
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
Ranger Smith
Posted: 06/23/22 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
That sounds like a thermostat issue.
EMD360
Arvada, CO
Posted: 06/23/22 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe. I checked that the thermostat wiring was secure but I probably need to put power directly to the hi fan wire.
EMD360
Arvada, CO
Posted: 06/24/22 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
It’s the high fan wire. It’s shorted out. I tested the thermostat and got a spark on the green wire. Took off the thermostat completely and got the same spark between the hot and hi fan. All the other functions work; low fan, compressor, and heat. Apparently auto hi and auto lo do nothing. I’m not sure why they cycle through. So sounds like I need to find the short! That does not seem like it’s going to be easy. On the other hand I could just tape it off. The air works fine on low cool. I found the only difference between the lo cool and hi cool is the fan speed. I hope I didn’t fry the thermostat when the green wire sparked!
EMD360
Arvada, CO
Posted: 06/28/22 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
I could not figure out why the high wire doesn’t operate. There is no speed selector switch to test. The wires are plugged into the control board.
Unfortunately I think I blew the electronic compressor circuit on the expensive Bluetooth thermostat because when I hooked it back up the compressor would not stay on. I re-installed the original thermostat and it’s working. I didn’t hook up the hi fan since it sparks on application of power.
So it could be the wire or the control board I guess.
The impeller turns freely as does the fan blade but I noticed the impeller has a chip in it wher part of a fin is broken off. That seems weird.
