RV.Net Open Roads Forum: Tech Issues: Air conditioner stopped working
 > Air conditioner stopped working
EMD360
Arvada, CO
Posted: 06/09/22 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
It hums for awhile but does not kick on. It’s a Coleman 48000 series. 15,000btu.
Owners manual says the compressor might not kick on if the filter is dirty but it’s not. Also that there is a high pressure lockout switch. I have not gone up to check out the unit. Any hints about what to test or look for? Just clean it and see if the problem persists?
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
Ranger Smith
Wherever the rig is parked
Posted: 06/09/22 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Bad start capacitor
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
jdc1
Rescue, Ca
Posted: 06/09/22 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
What Ranger Smith said.
https://www.rvupgradestore.com/Coleman-Mach-Hard-Start-Kit-p/48-1759.htm
EMD360
Arvada, CO
Posted: 06/10/22 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
Would a soft start device work instead? For 6 times the cost is it worth it?
Posted: 06/11/22 04:32am Link  |  Quote  |  Print  |  Notify Moderator
Might but I'd replace the start cap and install the softy start at the same time...
Bobbo
Wherever I park
Posted: 06/11/22 07:06am Link  |  Quote  |  Print  |  Notify Moderator
It's been awhile, but when I installed my Easy Start, it had me disconnect the soft start capacitor. (Now, the run capacitor stayed connected.) I am sure someone will correct me if I am wrong.
Bobbo and Lin
EMD360
Arvada, CO
Posted: 06/11/22 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I looked up this part and the 48000 series was not mentioned as compatible. But the parts list for this series lists the same part number. I’m capable of installing this myself but if it does not fix it I won’t be able to use my extended warranty. I bought it because we purchased the RV a year ago from a private party and we were taking it on a long trip. It was a decision based on what if? The deductible is $500. It is unlikely that the repair will cost that much. The insurance year ends on July 22nd. The rear brakes were replaced this winter and they were not covered because it was a maintenance item. Should I call and report this?
dougrainer
Carrolton, Texas
Posted: 06/11/22 10:34am Link  |  Quote  |  Print  |  Notify Moderator
1. A DIRTY filter will NEVER stop an AC from coming on.
2. I would replace the capacitor and see. That will cost less than $50. probably $20.
3. You CANNOT just report the problem to the ESC company. They will NOT give you any answer you want. What they will tell you is, Go to a Service Center, PAY for a diagnosis, then have the service center call the ESC with Part and Labor cost. Once it is determined it is a covered repair the ESC will issue a Auth number. If the bill is over $500, you pay $500 and the ESC covers the extra amount. If the bill is UNDER $500, you are on the hook for the Diag time(usually $150 to $200) then probably another $75 for a capacitor replacement plus part cost which will probably push the bill close to $400 to $450.
4. Odds are from your description you have a bad capacitor. Go up on top, remove the shroud, have someone start a Cool cycle while up on top. Give it 3 to 5 minutes. IF you do NOT hear the compressor start to hum a few seconds the capacitor is probably bad. IF you hear the compressor try to start(you will hear it) then it is possible the Compressor is locked up, BUT I would spend the few dollars and replace the Start capacitor.
5. IF after the capacitor it does NOT start and you then hear the compressor hum when trying to start, then go to the service center and have them Diag the problem. DO NOT TELL THEM YOU HAVE DONE ANY WORK. IF the compressor is bad, RV AC unit compressors are never replaced, they do not even have them as a replacement part. You will get a new upper AC unit and THAT $500 will be well spent as a new AC with labor will be around $1000 to $1500.
6. BAD NEWS is this. IF you need a new upper unit, odds are they are out of stock due to Covid supply parts issues. So, it may be months before they can get a new unit. Doug
EMD360
Arvada, CO
Posted: 06/11/22 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Thanks so much. I agree to try it. OEM part is $45 at Camping World and might be able to pick up today. I need to find out before Monday so I can call them. No I guess not. Ordered through Amazon but delivery will be next week. Guess there is no real hurry. I did not order the run capacitor too.
Thanks.
* This post was edited 06/11/22 11:29am by EMD360 *
time2roll
Posted: 06/11/22 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Call and ask for a preferred shop to look at and fix the issue. No self diagnosis here.
If you start a repair or modification yourself the warranty could again be denied. They will assume the trouble is related to your fix.
675w Solar pictures back up
