RV.Net Open Roads Forum: Tech Issues: Composting toilet - pros and cons
 > Composting toilet - pros and cons
Cptnvideo
Arizona - most of the time
Posted: 06/11/22 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Considering changing to a composting toilet (we boondock about 70% of the time).
I would like to hear the pros and cons from those that either have one or have done some research.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, 3kw inverter/charger, 3 206AH LiFePo4 batteries
theoldwizard1
SE MI
Posted: 06/11/22 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
From my research, the biggest down side is making sure to keep the urine and feces separated. The urine will smell very quickly. Much quicker than the feces.
Urine needs to be emptied often (daily ?) While feces covered with a dry compost can go several days, maybe a week.
If possible, the unit should be stored in a semi-sealed compartment. A small fan blowing up through a pipe and out the roof helps a lot with smell.
Chemical camp/cassette toilets are another alternative. They require some water and need to be emptied more often the true compost toilets. These can be emptied into a standard toilet.
I will never own another RV with a black water tank.
phillyg
SWFL
Posted: 06/12/22 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Don't have one, but my research told me to get the type with the small fan, urine seperator, and manual mixer thingie.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
valhalla360
No paticular place.
Posted: 06/12/22 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
We had one on the boat for several years.
For more typical RV use (ie: limited boondocking of a few days or less), tanks are much simpler and easier to use.
If you will be boondocking where you can't drain the tank for longer periods, they can be advantageous but usually, you will run out of fresh water about the same time as the traditional tank systems fill up.
Probably the biggest issue is what to do with the urine tank. It needs to be emptied every 2-3 days (assuming 2 people). If you are camping where there are toilet facilities, it's viable as you can pour the liquid in the toilet. Just dumping it on the ground is likely to get you some nasty comments if you are caught.
Odor is one of the biggest reasons to get one (though not so much of an advantage in an RV...boats are notorious for smelly heads but the plumbing is much different). If there is odor, you are doing something seriously wrong. They are pretty simple to use correctly. No you don't want liquids in the solids tank but they are designed to separate.
- As mentioned, liquid tank is emptied every 2-3 days.
- Solids we were good for around a month. Usually, it would be bagged and put in a dumpster (no worse than baby diapers...actually less offensive). Assuming you can let it compost for a couple days, looks and smells like rich earth when emptying. If you can let it fully compost (a couple months), it's great for the flower beds.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
