dessa1930
north carolina
i have about 10k miles towing on my 33 ft tt
thought i would check the brakes and pulled drum of
to my surprise i only one wheel had any brake lining left
i was stopping with only 1 wheel brake
do brake shoes not last that long on a tt
80% of travel is on interstate so i dont use them that much
they have never been overheated or never notice them dragging or running hot when on road
is this normal
WayneAt63044
St. Louis, MO
I find that unusual. Did you buy the trailer new to know the brakes only have 10K miles on them? I find the self-adjusting version run warmer as the shoe is always rubbing and have replaced mine with manual adjust versions.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
QCMan
Independent Republic of Horry
You did not say how old the trailer is but an awful lot of trailers have been produced with manually adjusted brakes and then lots more with reverse adjusting brakes. The newer forward adjusting brakes tend to be better but a yearly check when you repack the bearings and put a new seal in can give you an insight into how well adjusted your brakes are. You seem to have one that was adjusted too loose compared to the others and that is why it still has material left.
When was the last time you checked them?
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
dessa1930
north carolina
its a 2002 model and i did buy it new
it has manual adjusting brakes
several years since i have checked them as we only camp 1 time a year for a month at a time and its only about 250 mile round trip
dessa1930 wrote: its a 2002 model and i did buy it new
You’re insinuating that last time you checked them they didn’t show a great amount of wear?
But you must’ve noticed they didn’t work right for how long?
Regardless, none of that matters it’s 20 years old and from what you’ve described, no one could say whether that is expected or not.
2017 Heartland Torque T29
katysdad
Virginia
Have seen several where the linings come off the shoe itself then break into small enough pieces to come out of the drum. Most found when checking wheel bearings and not a brake complaint. seems like the bonding agent failed to hold the lining. Some still had the lining loose inside the drum.
Dodge Ram 3500 DRW Diesel
southernsky
Ponchatoula La.
No that's not normal. I have a 40' fifthwheel and have over 40,000 cross country mls on it and pads still looked good. I just changed over to disk brakes. I would say you're dragging your brakes or you have too much brake in you brake adjustment in your truck if they wore out that quick
2022 Renegade Super C
2020 Ford Ranger 4x4 Sport
dodge guy
Bartlett IL
Brake material gets brittle as it gets old. So it may have just broken apart while driving/braking over the last few years.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
eHoefler
ozark mountains
After having the linings come off the shoes 3 years in a row and taking out the drums the 3rd time, I bit the bullet and installed disc brakes. It was going to be $1300 to replace all the brakes and drums, I bought everything to install disc brakes for $1600. It took less than a day to install, and haven't looked back.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
phillyg
SWFL
Should be able to get much more than 10,000 miles on drum brakes.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
