Thermoguy
Graham, WA
How are you reading the voltages? Can you trust your meter? Some can be off a few tenths of a volt to more. Check that before you go too far.
joelyn
Az
thanks for the info, i will check the charger out and check the batties again and report back. thanks
joelyn
Az
![[image]](https://i.imgur.com/41ddQ4Cl.jpg)
SEE NEXT PICTURE ALSO,,,xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
edited 06/12/22 01:26pm by joelyn *
joelyn
Az
ok retested the batteries this morning and both read 13.3... here are a couple pictures of my charger info and the info on the battery. maybe this can help in helping with my problem, if any... thanks again to all for the help;;;
Thermoguy
Graham, WA
Why does that say for 12-35Ah Batteries only?
joelyn
Az
DON'T KNOW,, thats what came with the scooter when i got it 4 years ago... it worked fine for all those years with the batteries which came on the scooter which are the same as the new ones just a different brand.. old batteries where for 2016 and started to lose charge pretty quick when in use...
CA Traveler
The Western States
12V (volt), 35Ah (amp hour) rated battery capacity. 24V output means 2 series batteries for double the capacity (24V @ 35Ah).
2014 Grand Cherokee Overland
Bob
joelyn
Az
CA Traveler wrote: 12V (volt), 35Ah (amp hour) rated battery capacity. 24V output means 2 series batteries for double the capacity (24V @ 35Ah).
that sounds good, just why I have in there,,,,,
joelyn
Az
everything back together and drove the scooter around a little and seems fine. will be using it the next 5 days so will see how the batteries do. maybe will put a couple leads to the pos and neg terminals so they are on the outside and than i can test the volts on the batteries each day without having to remove the shroud. thanks again to all for ALLLL ur help and advise... will check back in a week or so and let u know how they did... stay safe...
2112
You have the correct batteries for the charger.
The ELECHG1024 has gone through some evolution. The earlier version was A24030-9C. It was upgraded to the A24030-10C, which you have, then upgraded again to the currently available A24030-10D.
I was unable to find details on your -10C. I did discover the -9C should output 29.7V, which is 14.4V per battery. As mentioned above, your meter could very easily be off by that much, which is 1%.
Use it to put it through a few cycles and contact Pride if you still have a concern.
2013 KZ Durango 2857
