joelyn
Az
xxxxx UPDATE xxxxxx, USED THE SCOOTER FOR THE PAST WEEK and even after 4 days of good use the batteries still showed a full charge... on the 5th day of use the meter dropped one green light.. put it on the charger for a few hours and back to full for the next few days.
I contactED the mighty max battery company in NJ and explained to the tech about the 15.2 volt reading and still charging and without hesitation he stated that that volts concerned him and believed that i received a defective battery... they sent a new one out yesterday and a return paid postage to return the other battery for them to check... should have it by the end of the week and will install it and let u know the findings with the new one....
seems like a pretty good company to deal with... AGAIN THANK YOU ALL FOR YOUR RESPONSES AND ADVISE....................
time2roll
Not sure I understand how a bad battery would cause the charger to put excess voltage on the battery.
Has the voltage been verified with a separate voltmeter?
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Vintage465 wrote: jkwilson wrote: wa8yxm wrote: They need to be "Equalized" how to do that on your system I do not know. I know how I'd do it but it requires hooking them in parallel to a DIFFERENT charger.
Don’t equalize AGMs. It will damage them.
True statement. Everything I've read is that AGM's aren't supposed to be equalized.
Lifeline calls it "conditioning" charge. It is, defacto, an equalization charge.
https://lifelinebatteries.com/can-i-equalize-agm-batteries/
Regards, Don
time2roll
And only to be done when there has been a significant loss of capacity. Not as a regular charging pattern.
2112
Thanks for the update
A higher internal resistance would explain the imbalance of 14.8V and 15.2V while charging. The battery measuring 15.2V would have a higher internal resistance. Maybe that's what they found troubling.
Jocelyn - Take the following measurements once you have the new battery installed:
Voltage of each bat and combined voltage of both bat's before you start initial charge. Should be ~ 12.7V each and 25.4V combined
Same measurements as above at the beginning of the charge. Of course the voltage measurements will be higher. The individual bat measurements may not be identical but the total should add up the measured combined voltage.
Same as above after a 30 minute charge. The individual measurements should be getting close to being the same voltage, 14.x
At some point you should expect each battery to measure 15.0V and the combined voltage to measure 30.0V. From your previous measurements it appears either your charger outputs 30V or your voltmeter is a little off.
On Edit: Now my curiosity is kicking in.
Before you replace your battery, charge what you have again to see if you still measure 14.8V and 15.2V. I'm curious to see if they balanced out after using them for a short time. You may find that they measure the same now.
edited 06/22/22 05:01am by 2112 *
2013 KZ Durango 2857
You are mistaken. They need to be equalized. But the procedure is different for those batteries.
Basically they need to be charged independently on a 12 volt charger
or charged in parallel on a 12 volt charger.
Charging them in series when they are not equally discharged results in one being over charged and the other under charged.
I see people yammering about different size 12 volt batteries in parallel. they make the very claim I just stated.. Which is not true for batteries in parallel.
But batteries in SERIES need to be identical
Same size
Same capacity
SAME STATE OF CHARGE. (Equalized).
And the easiest way to do that is to put 'em in parallel and use a 12 volt charger.
