RV.Net Open Roads Forum: Fifth-Wheels: Cedar Creek rear cap cracks
 > Cedar Creek rear cap cracks
Lantley
Ellicott City, Maryland
Posted: 06/13/22 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
yellow dog wrote:
Doug - You explained the exact procedure on how to repair from someone else I spoke too. What is the expectancy of the repair in your opinion...in mine if the repair is done correctly should last as long as the rest of the cap. Also, not sure I'm following you with the paper trail, when I noticed it out of the gate, I brought it to dealer's attention, they made arrangements to repair. Bottom line is, it was not done properly and here I am.
When you have a problem like you have, you get EVERYTHING in writing. You also ask both the Dealer and FR and the Body shop what warranty they will supply for the repair. GET IT IN WRITING. I doubt most body shops would warranty a repair on an RV for more than 1 year. One thing a LOT of people do not realize on warranties is this. True for both Auto's and RV's. The warranty period is for the term for the OEM. For instance, you have a 1 year warranty. At 11 months they replace the Water pump. Your warranty on the Water Pump is 1 month, NOT 1 year from the replacement. Same with Auto's. 3 year warranty. At month 35 they replace the Alternator. Your warranty is 1 month NOT another year or another 36 months for the Alternator. Some Body Shops warrant for lifetime you own the CAR for body work. Most do NOT. Doug
Which is why at this point the easiest way to resolve the matter is to simply pay to have it fixed.BTDT
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Krusty
Calgary, Alberta,Canada
Posted: 06/13/22 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Now that you are an expert on how to do the job correctly, and exactly how long it should last, why not just do the repair yourself?
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
Esacnj
NJ
Posted: 06/16/22 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I guess it's unreasonable to think that a repair should correct a problem for good rather than just long enough to get past a warrantee period. Unfortunately for everyone this has become the norm across the board no matter what you have done. Sad state of affairs.
* This post was edited 06/16/22 11:35am by Esacnj *
Lantley
Posted: 06/16/22 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately in the RV world the goal is to clear the warranty period.
shadows4
Kansas City, Mo
Posted: 07/16/22 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Curious as to what the OP'er did to fix the problem?
2003 4X4 F350,CC,SB,Lariat,7.3L diesel, 223,000 miles
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
FlatBroke
CO/AZ
Posted: 07/17/22 07:26am Link  |  Quote  |  Print  |  Notify Moderator
If everyone gave a 4 year warranty on an RV they would all go broke.
Hitch Hiker
"08" 29.5 FKTG LS
Esacnj
NJ
Posted: 07/17/22 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Unless they fixed it right the first time.
yellow dog
PA
Posted: 07/17/22 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Shadows4 - I called the repair guy that originally did the repair for my dealership. He basically told me, he can't be responsible for anything beyond 1 year. I also called someone I was put in contact with that does fiberglass / body work. He told me the issue was caused by not prepping the area properly, which would cause the fade and clear coat to peel. I haven't decided if I'm going to have it repaired yet or not, but one thing is for sure, I will not be taking it back to the guy the dealership uses...
