RV.Net Open Roads Forum: Tech Issues: Do I need a better converter?
 > Do I need a better converter?
mooky stinks
Cicero,NY
Posted: 06/13/22 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Just replaced original 80ah battery with 2 100ah batteries. When dry camping for 3 nights the batteries were steadily lower after each charging during the allowed generator times. 1st night when fully charged they dropped to 60%. 2nd night they started out at 85% and dropped to 50% then 3rd was about 70% to 30%. I never saw higher than 13.7 when plugged in to my 2000watt generator. Haven’t looked at what my converter is rated for yet but am I right in thinking it’s just not putting the charge back in fast enough? Would a stand alone commercial battery charger that I have work better in the few times a year I dry camp? Any suggestions would be appreciated!
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
mbopp
Henrietta, NY, USA
Posted: 06/13/22 07:44am Link  |  Quote  |  Print  |  Notify Moderator
If it's a WFCO converter they're notorious for not going into bulk charging mode. I have 2 GC batteries and an IOTA-55 converter for faster charging off a generator.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
librty02
Western Pa
Posted: 06/13/22 08:44am Link  |  Quote  |  Print  |  Notify Moderator
You did not state what type of batteries you got are they FLA or LifePO4?
2011 FORD F-150 FX4 CREW CAB ECO...
2018 Ford F-150 Max Tow Crew 6.5 3.5 Eco...
2013 Keystone Passport 2650BH, EQUAL-I-ZER 1K/10K
StirCrazy
Kamloops, BC, Canada
Posted: 06/13/22 08:50am Link  |  Quote  |  Print  |  Notify Moderator
need a little more context here, what kind of batteries, what is your converter now and how long are you running the generator for.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
theoldwizard1
SE MI
Posted: 06/13/22 08:54am Link  |  Quote  |  Print  |  Notify Moderator
The short answer is TES !
Now would be a good time to upgrade to an inverter/charger/automatic transfer switch.
valhalla360
No paticular place.
Posted: 06/13/22 08:58am Link  |  Quote  |  Print  |  Notify Moderator
What is the charger and how long were you running the generator?
First morning 60% to 85%, is 25% of 200ah or 50ah. A 50amp charger should do that in around an hour.
Second morning 50% to 70%, is 20% of 200ah or 40ah. Should take 20% less charge time to get there.
Did you per chance run the generator for 1:15 the first time and 1:00 the second time?
You generally won't get to 100% charging with an hour or two on the generator (even if the charger puts out enough amps). Lead-Acid batteries start reducing the charge acceptance around 70%. At first it's a minor reduction. By the time you get to 80-90%, they accept far lower amperages, no matter how big the charger is.
If you will be boondocking another option is to get something like a 100w portable solar panel.
- Run the generator first thing in the morning to get up around 80-90% (an hour or two).
- The solar panel will peak around 8amps mid day but it will do so over several hours and top up the remaining storage.
Of course, if you do a lot of boondocking, a large permanently installed solar array is a nice option but it brings it's own set of costs/complications.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Posted: 06/13/22 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Probably your converter is a POS.
After having 2 campers with PD converters and not knowing or caring really "why" people said WFCOs are junk, we got a camper with a WFCO. Can confirm, it's a pile of doo doo.
CA Traveler
The Western States
Posted: 06/13/22 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Read up on bulk, absorb and float charging. The voltage should rise to 14.4V+.
2014 Grand Cherokee Overland
Bob
mooky stinks
Cicero,NY
Posted: 06/13/22 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Ok I’ll try to give some more info. They are regular lead acid. First night they were 100% because it had been parked in my driveway plugged in for 2 weeks. I was charging for 2 hrs in the morning and 3 hrs in the evening. I did periodically shut the converter off to run a microwave but that was very limited. Probably 15 minutes total per day. I’ll have to look but I know I have a WFCO 8930/50. Trailer is 50 amp. There is a breaker that says converter. Am I right in thinking it is a separate unit?
time2roll
Posted: 06/13/22 10:18am Link  |  Quote  |  Print  |  Notify Moderator
https://powermaxconverters.com/product/pm4-series-2/
I recommend the 35 or 45 amp with just two batteries.
https://www.bestconverter.com/PD-9260C-60-Amp-RV-ConverterCharger
PD is fine at 60 amps.
(edit to reflect WFCO 9800 posted after)
* This post was last edited 06/13/22 02:44pm by time2roll *   View edit history
675w Solar pictures back up
