RV.Net Open Roads Forum: Tech Issues: Alternative to 4wd
 > Alternative to 4wd
fourthclassC
MA
Posted: 06/13/22 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Howdy, has any one installed a rear locker on their differential? I have a 02 Ford E350 with V10 and would like to install an electric locker to help free the vehicle when stuck in mud, wet grass, snow....... I have found that being such a heavy vehicle is no help in some situations. 4wd conversion I.E. Quigly.. is too expensive and would not be necessary. From driving a pick up with rear locker, I think that is the answer for me. Any product recommendations?
Thank you
Gdetrailer
PA
Posted: 06/13/22 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
I buy and own nothing but 2wd F250s, older ones made sure they were optioned with limited slip, new ones with Electronic Locking axles as Ford n longer offers Limited slip in pickups.
The factory Electronic locking axle is somewhat of an improvement over open or limited slip.
Does not and will not replace 4x4.
In other words, you still can get stuck on wet grass and mud if not careful.
RetiredRealtorRick
St. Augustine Beach, FL
Posted: 06/13/22 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
Why not mount an electric winch on the front end? That way it's there if you need it, plus it just looks kinda cool! [emoticon]
. . . never confuse education with intelligence, nor motion with progress
Posted: 06/13/22 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Derp...
Southern California :(
Posted: 06/13/22 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
I was happy with my Chevrolets that had 2WD limited slip differentials.
time2roll
Posted: 06/13/22 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
I changed my factory limited slip (F150) to an Eaton TrueTrac geared limited slip. Terrific improvement without the locker issues. Excellent for the situations described. Not as effective as a locker if a wheel is suspended from rock hopping etc. Still great with 100,000 miles on it.
675w Solar pictures back up
valhalla360
No paticular place.
Posted: 06/13/22 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
It won't match 4x4 but it will certainly help. An electronic locker will beat a limited slip because the limited slip doesn't fully engage the 2nd wheel until the 1st wheel is already slipping (static friction is typically better than sliding friction)
The extra hitch weight will also help a lot when hooked up to the trailer.
If you are looking for heavy duty off roading, 4x4 is needed. If you just want to avoid getting stuck in slippery but otherwise non-challenging conditions, it can be a nice upgrade.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Sjm9911
New Jersey
Posted: 06/13/22 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Your from MA , you know that in the snow and such rear wheel drive is the worst. Are you talking about getting to campsites? Or just in general. I dont think it will help that much. We have simmiler on fire engiens, in the snow mud and stuff we need chains. The traction control that would lock the back wheels dosen't help at all. At least I have never had 1 situation where it did. And yea, the weight dosen't matter in certain situations. How about pads, or a chain mat to put down after you get stuck?
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
ktmrfs
Portland, Oregon
Posted: 06/13/22 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
my duramax has an auto locker rear, better than an open diff, but still easy to have issues on wet grass, mud etc. Even with traction control. shift to 4wd (really 3 wd) and what was marginal was easy peasy
2011 Keystone Outback 295RE
Gdetrailer
PA
Posted: 06/13/22 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
No need to be condescending on having 2wd in the north east, folks do have reasons as to why no 4x4 on a vehicle..
OP is talking a VAN chassis motor home, not saying they don't make 4x4 van chassis motor homes but in the whole realm of reality you most likely will find far fewer 4x4 van chassis motor homes built and sold than 4x2.
4x4 adds considerable weight and cost to the vehicle and you take a already heavy RV and drag another 800 lbs around and tacking on an extra $$$$ to the price tag in the hopes you might need it.
Price a 4x2 motor home and then a 4x4 motor home and see just how deep your pockets are..
Myself, have saved well over enough money over the yrs to buy a brand new 4x2 truck for cash just by not paying an extra $4K per vehicle..
Only can count on one hand the times it would have been nice to have 4x4 over the last 30 yrs and I live in the the north east.
