RV.Net Open Roads Forum: Tech Issues: E vs. D rated trailer tires
 > E vs. D rated trailer tires
theoldwizard1
SE MI
Posted: 06/14/22 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Forget ST tires. Use LT tires. Many more brands and sizes to choose from.
Letter and ply rating are "old school" and should not be trusted. Use the actual weight rating on the sidewall. It will also tell you the correct pressure.
phillyg
SWFL
Posted: 06/14/22 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
It probably won't ride harder if you adjust your psi downwards, based on your actual weight, and using the tire mfgrs. load table. And, congrats on getting 5 years on Trailer Kings, most fail well before then.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Cummins12V98
on the road
Posted: 06/14/22 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
2112 wrote:
I had Ds on my FW and kept them aired up to 65psi. I upgraded to Endurance Es and air then up to 68psi.
I tried then at 75psi and it was like the FW was riding on basketballs. Aired them down to 68 and now it rides smooth as glass.
The load chart was about 55psi for my weight
Nice seeing a Man using the brain God gave him.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 06/14/22 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Correct pressure for what???
theoldwizard1
SE MI
Posted: 06/14/22 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Correct pressure for the rated load.
CapriRacer
Somewhere in the US
Posted: 06/15/22 04:18am Link  |  Quote  |  Print  |  Notify Moderator
I see no one has mentioned that a Load Range E has the same load carrying capacity as a Load Range D when inflated to the same pressure. At the LR D pressure, a LR E performs the same - ride, sway, etc.
So you can buy a LR E and use it in place of a LR D.
* This post was edited 06/15/22 04:24am by CapriRacer *
CapriRacer
Visit my web site: www.BarrysTireTech.com
2112
Posted: 06/15/22 06:57am Link  |  Quote  |  Print  |  Notify Moderator
It was a pease of mind for me. One less thing to worry about.
Actually they have about 18% more capacity when inflated to the same pressure when comparing the 75R15(D) and 75R15(E).
Endurance Load Chart
I have 8400lbs across 4 tires. So according to the chart I should air them to 50psi. Even at 55psi they looked too low and would have too much sidewall flex. 68psi just looks and feels right to me. YMMV
* This post was last edited 06/15/22 07:36am by 2112 *   View edit history
2013 KZ Durango 2857
Cummins12V98
on the road
Posted: 06/15/22 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Thought for a minute you were a fill it to MAX psi no matter what kinda guy.
Cummins12V98
on the road
Posted: 06/15/22 07:49am Link  |  Quote  |  Print  |  Notify Moderator
CapriRacer said: "I see no one has mentioned that a Load Range E has the same load carrying capacity as a Load Range D when inflated to the same pressure."
I kinda did say it in code: "but if close to the MAX rating buy the "E" and run them at the same pressure as the "D" tires required."
Cummins12V98
on the road
Posted: 06/15/22 07:51am Link  |  Quote  |  Print  |  Notify Moderator
My Endurance on my Boat Trailer "LOOK" low but the proof is in the pudding they are right on at 50psi as the tread is perfectly even at 20,000 miles.
