Hemling
Miami, FL
We are moving back to WI after 4 years of living in Miami and I'm making my list of items to address since my unit is 5 years old. One of those is tires. I still have the stock 'Trailer King" D rated tires, and will be changing them out. What exactly is the rationale behind going to an 'E' rated tire on a camper? Obviously more load carrying capacity I understand, but does it ride harder then too? I certainly don't need more jarring transmitted to the chassis. I feel like if you need the load carrying capabilities of a higher rated tire you might also be overloading the chassis. Is it just higher quality of tire? Kind of like going to an 'F' when an 'E' will do the job more comfortably. Is it just peace of mind / bragging rights?
MFL
Midwest
In many cases the OEM supplied tires are just barely sufficient, for the trailer at full GVWR. They even take into consideration, that some of the wt will be carried by the hitch.
If D-rated tires are adequate for your trailer wt on the axles, then no need to go to E-rated. If your current tires are at the edge of needed rating, then moving up may be a good idea.
Jerry
fj12ryder
Platte City, MO
Some people have moved from D-rated ST tires to E-rated LT tires due to the better, IMO, construction of the LT tires. But you need to move up a rating to get the carrying capacity.
Howard and Peggy
"Don't Panic"
schlep1967
Harrisburg, PA
You will need to do some math. Look at the sidewall of your current tires for max weight capacity. It will look something like 2500 @ 60 max inflation. Take the Max number times the number of tires. In the example above 2500 x 4 = 10,000 lbs. If your trailer GVWR is less than the total amount you don't need a higher rated tire.
If you do go to a higher rated tire you most likely would not need to run them at maximum pressure. There are tire pressure charts out there from most reputable tire manufacturers so you can match the pressure to the weight of the trailer. This would reduce some of the bounce.
2021 Chevy Silverado LTZ 3500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide 4500
valhalla360
No paticular place.
schlep1967 wrote: You will need to do some math. Look at the sidewall of your current tires for max weight capacity. It will look something like 2500 @ 60 max inflation. Take the Max number times the number of tires. In the example above 2500 x 4 = 10,000 lbs. If your trailer GVWR is less than the total amount you don't need a higher rated tire.
One thing missing from the above is the hitch weight isn't riding on the tires.
A 12k GVWR 5th wheel with 2500lb on the pin, is fine with 2500lb tires. as there will be at most 9500lb on the 4 tires (assuming you don't exceed GVWR).
Moving up one notch on the tire ratings, is generally going to be fairly harmless. Jumping up multiple notches will do exactly what the OP is concerned about. There's going to be very little give in the tire and that will transfer to the suspension, frame and rest of the trailer.
To give you an idea: If you've ever rode in a 3/4 or 1 ton pickup that's empty. The ride is very jarring over bumps (tires/suspension are very firm). Load up 1500-2000lb in the back and the ride smooths out a lot because the tires and suspension are absorbing rather than transmitting the forces.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
time2roll
Get the GY Endurance tires. Probably E rated depending on size. If the ride is bad at 80psi then drop it down to 70-75 psi. But I think it will ride better not worse. Higher margin of load rating will reduce the chance of tire failure. Most factory tires are very close to max rating and is part of the reason people have tire failures.
675w Solar pictures back up
Hemling
Miami, FL
I get the same thing in my Excursion. I have 1 ton rear overload springs and with tires at 80 psi it rides great towing our camper. However, after unhooking and driving around 'empty' it is like a dumptruck.
Tire/wheel size and load rating (D obviously, but weight rating) and camper weight needed to make any accurate recommendation.
Cummins12V98
on the road
time2roll wrote: Get the GY Endurance tires. Probably E rated depending on size. If the ride is bad at 80psi then drop it down to 70-75 psi. But I think it will ride better not worse. Higher margin of load rating will reduce the chance of tire failure. Most factory tires are very close to max rating and is part of the reason people have tire failures.
I agree on the ENDURANCE.
Bottom line know what each axle and preferably what each tire is carrying. If the "D" tire has plant of capacity for your weight then stick with "D" but if close to the MAX rating buy the "E" and run them at the same pressure as the "D" tires required. Better yet use the load inflation chart for the "E" and add 5 psi to what the chart dictates.
My Boat Trailer had "C" tires in 14" and I changed to "D" ENDURANCE and guess what the "C" inflation of 50psi was correct for the new "D" tires. 20k with plenty of tread left and wearing perfectly even.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
2112
I had Ds on my FW and kept them aired up to 65psi. I upgraded to Endurance Es and air then up to 68psi.
I tried then at 75psi and it was like the FW was riding on basketballs. Aired them down to 68 and now it rides smooth as glass.
The load chart was about 55psi for my weight
2013 KZ Durango 2857
