RV.Net Open Roads Forum: Fifth-Wheels: Alignment shop
 > Alignment shop
flyfishing48
Green Valley AZ
Posted: 06/14/22 06:06am Link  |  Quote  |  Print  |  Notify Moderator
Seeing some uneven tire wear on right front and left rear tires. Both Goodyears and about 7;000 miles. Other two look normal. Replaced the two worn ones and watching closely. Looking to have axle alignment checked in Green Valley/Tucson area. Any recommendations ?
Gloria & Tom:">
Chevy 2500 Crew Cab Duramax
Cougar 24 RDS
B&W Companion Hitch
corvettekent
Marysville, WA
Posted: 06/14/22 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Take it to a truck frame and alignment shop. You should also check and/or replace the leafspring bushings and shackles with a wet bolt kit.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Turnover Ball, Companion Hitch.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
CA Traveler
The Western States
Posted: 06/14/22 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Make sure it's not river edge wear which is a tire defect.
2014 Grand Cherokee Overland
Bob
flyfishing48
Green Valley AZ
Posted: 06/14/22 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler I was not familiar with the term river wear. After looking into it my tires were something in between river wear and shoulder step wear. Both have no correction steps listed. So I may be alright. I have 2 new tires to replace the worn ones and will watch them close.
I put the new ones on in OK city and I am now in Pa and head back west next week. We shall see what transpires.
Thanks
flyfishing48
Green Valley AZ
Posted: 06/15/22 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Corvette Kent. The 5er is only in its second season, but wet bolts are on the short list soon.
DickOK
Tucson Arizona
Posted: 06/15/22 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
I take my 5th wheel to Arizona Spring on Grant in Tucson. They do my wheel bearings and check the alignment They had to repair the alignment once. Fair price.
Dick OK
time2roll
Posted: 06/15/22 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Did tire pictures get taken to help the shop diagnose the wear issues?
675w Solar pictures back up
flyfishing48
Green Valley AZ
Posted: 06/15/22 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, if I have a repeat of the wear when I get back I’ll look them up.
flyfishing48
Green Valley AZ
Posted: 06/15/22 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
I know I took pictures of the codes on the sidewall, not sure about the wear pattern. But not to worry, once I return, if it is an alignment issue and not a defect they will have a fresh sample.
C Schomer
Pueblo West, Co.
Posted: 06/17/22 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
A friend with an 05 Cedar Creek with a lot of miles on it had one tire position trashing tires at the drop of a hat. He took it to the trailer shop and they replaced all the bushings and no more problem. I wouldn’t think bad bushings would do that much damage but he said that was the only problem. I’d start there. Craig
 > Alignment shop
