flyfishing48
Green Valley AZ
Seeing some uneven tire wear on right front and left rear tires. Both Goodyears and about 7;000 miles. Other two look normal. Replaced the two worn ones and watching closely. Looking to have axle alignment checked in Green Valley/Tucson area. Any recommendations ?
Gloria & Tom:">
Chevy 2500 Crew Cab Duramax
Cougar 24 RDS
B&W Companion Hitch
corvettekent
Marysville, WA
Take it to a truck frame and alignment shop. You should also check and/or replace the leafspring bushings and shackles with a wet bolt kit.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Turnover Ball, Companion Hitch.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
CA Traveler
The Western States
Make sure it's not river edge wear which is a tire defect.
2014 Grand Cherokee Overland
Bob
flyfishing48
Green Valley AZ
CA Traveler I was not familiar with the term river wear. After looking into it my tires were something in between river wear and shoulder step wear. Both have no correction steps listed. So I may be alright. I have 2 new tires to replace the worn ones and will watch them close.
I put the new ones on in OK city and I am now in Pa and head back west next week. We shall see what transpires.
Thanks
flyfishing48
Green Valley AZ
Corvette Kent. The 5er is only in its second season, but wet bolts are on the short list soon.
DickOK
Tucson Arizona
I take my 5th wheel to Arizona Spring on Grant in Tucson. They do my wheel bearings and check the alignment They had to repair the alignment once. Fair price.
Dick OK
time2roll
Did tire pictures get taken to help the shop diagnose the wear issues?
675w Solar pictures back up
flyfishing48
Green Valley AZ
DickOK wrote: I take my 5th wheel to Arizona Spring on Grant in Tucson. They do my wheel bearings and check the alignment They had to repair the alignment once. Fair price.
Thanks, if I have a repeat of the wear when I get back I’ll look them up.
flyfishing48
Green Valley AZ
time2roll wrote: Did tire pictures get taken to help the shop diagnose the wear issues?
I know I took pictures of the codes on the sidewall, not sure about the wear pattern. But not to worry, once I return, if it is an alignment issue and not a defect they will have a fresh sample.
C Schomer
Pueblo West, Co.
A friend with an 05 Cedar Creek with a lot of miles on it had one tire position trashing tires at the drop of a hat. He took it to the trailer shop and they replaced all the bushings and no more problem. I wouldn’t think bad bushings would do that much damage but he said that was the only problem. I’d start there. Craig
