RV.Net Open Roads Forum: Fifth-Wheels: AC on or off?
 > AC on or off?
Gooselover
NE OK
Posted: 06/14/22 09:56am Link  |  Quote  |  Print  |  Notify Moderator
When your 5'ver is at your house parked and you are NOT IN IT for a while, do you leave your AC on auto or turn completely off? It is very hot here in Oklahoma, and right now the AC units are OFF completely. Should I be concerned with the unit heating up inside?
Charlie & Jeri
2013 Keystone Cougar 327RES
2013 Dodge Ram 3500 EC
MFL
Midwest
Posted: 06/14/22 10:25am Link  |  Quote  |  Print  |  Notify Moderator
If just parked, not going to use for a while, I set the stat to auto 88 degrees during extreme heat.
Jerry
Janss
Sedona, AZ
Posted: 06/14/22 10:47am Link  |  Quote  |  Print  |  Notify Moderator
I do the same as Jerry. I leave toiletries and some canned and dry food in there all the time. I don't imagine extreme heat is good for the materials like plastic that RVs are made with. I've had some little rubber dots on the cabinet doors to melt.
Also make sure a little water stays in your toilet bowl at all times to keep the seal moist. I've had to add some water every now and then due to evaporation.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
way2roll
Wilmington NC
Posted: 06/14/22 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Just curious what harm can come from not turning on the AC. Lots of RV's (mine included) are in storage or on dealer lots where there is no electric. It gets hot here in the summer. Today is close to 100 with heat indexes as high as 112. I've never had an issue as a result and don't recall reading complaints about issues from not running the AC. I keep the blinds closed when in storage mainly to prevent any fading on interior surfaces. Unless I am missing something, running the AC is a solution looking for a problem. Maybe I am missing something - although if I am, it's a moot point for me as I don't keep my RV at my house.
* This post was edited 06/14/22 11:02am by way2roll *
2023 FR Sunseeker 2400B MBS
Second Chance
Wherever...
Posted: 06/14/22 11:58am Link  |  Quote  |  Print  |  Notify Moderator
It depends on how high the humidity is where you are. Moisture and mold will do as much or more damage than heat. ACs are great dehumidifiers. If you have good power, I would leave them on set low enough that they run off and on to pull out the moisture. Otherwise I would run a dehumidifier. If the average relative humidity is below 45%, just set the ACs where you want them to not cook the interior woodwork.
Rob
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
bobsallyh
Livingston, TX.
Posted: 06/14/22 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
There are thousands of RVs parked in parks in the Yuma, AZ. area for the summer at whatever temps. Yesterday 113 and will escalate as summer nears. No one lets their AC on!
Allworth
Orlando, FL
Posted: 06/14/22 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
He clearly said "at your house".
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
way2roll
Wilmington NC
Posted: 06/14/22 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, we get that. The answer is still the same. Just because you can doesn't mean you have to. The point being made is that there are way more RV's that don't run the air in hot climates that do and there are no real complaints about issues.
samsontdog
Oregon, Wash Coast summer, Yuma Az winter
Posted: 06/14/22 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have several rental houses in Yuma that I rent out during the winter
and I never leave the elect on during the summer. Every thing is turned off for 6 months
samsontdog">">
Michelle.S
Western NY till fall, then Sebring, FL
This is one of those "It all depends".
If you're a weekender and not much of anything left inside, don't need AC on, remember there is no AC on in those units sitting all summer in RV Dealers across the country.
Now if you're like us and keep the unit loaded and ready to leave on a few hours notice, I guess I would run the AC some for reasons already suggested.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
 > AC on or off?
