RV.Net Open Roads Forum: House AC went out can I hook up to 20 amp gfci
 > House AC went out can I hook up to 20 amp gfci
Johnsonty131
Posted: 06/14/22 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Long story short ac part for house won’t be here till Saturday. 2021 keystone hideout 176bh says ac BTU is only 13,000. Can I safely run this from my normal house outlet? (I have the dog ear adapter for the 15 amp to 30)
midnightsadie
ohio
Posted: 06/14/22 10:45am Link  |  Quote  |  Print  |  Notify Moderator
be nice if it was a 20amp out let, and I,d not use any thing else on that line. I run my rv ac off one with no problem.
bgum
South Louisiana
Posted: 06/14/22 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Is your "normal house outlet" 120 volts or 240V?
If it is 120v then yes but I wouldn't run anything else such as converter/charger, fridge, water heater.
Johnsonty131
Posted: 06/14/22 10:53am Link  |  Quote  |  Print  |  Notify Moderator
I’m guessing 120 volt. All my house breakers say 20 also
way2roll
Wilmington NC
Posted: 06/14/22 11:07am Link  |  Quote  |  Print  |  Notify Moderator
One of the nice things about an RV is that if something like the heat or AC goes out in your house, you can use the RV. As others said, just run one AC and nothing else and you should be fine. Usually worst case, you trip a breaker. I had a previous Class A that didn't mind a 15A for AC. My current FW prefers a 20A - it will trip a 15A even with only one AC running.
Posted: 06/14/22 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Very likely yes. I have a less than ideal service to my shop and am able to run the AC on all of the campers we've had off of a 15A service.
But at some point (may not have been the camper AC) that outlet got hot.
I replaced with a 20A outlet (since it is only a few feet from the subpanel, and already on a 20A breaker) and that works like a charm.
Keep the extension cord short. If you're using just your RV cord with no additional extension cord(s), that is the best scenario.
Worst case, it pops the breaker feeding that outlet. No harm, no foul.
2017 Heartland Torque T29
Posted: 06/14/22 11:24am Link  |  Quote  |  Print  |  Notify Moderator
He said it was 20A in his title.
2112
Posted: 06/14/22 11:57am Link  |  Quote  |  Print  |  Notify Moderator
I do it all the time.
If you need an extension cord use a short 12AWG. Make one if you have to.
This is a bad week in Tx for losing your AC
2013 KZ Durango 2857
Sjm9911
New Jersey
Posted: 06/14/22 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
As they said, yes, mine will do the 13500 ac and the tv. Nothing else. But thats all I needed. Use a large guage extention cord. The rv one is ideal.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Sjm9911
New Jersey
Posted: 06/14/22 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Switch the fridge to propane if you can, I dont know if I had mine on or not.
