Johnsonty131
So my 5 breakers are 1 . Interior zone 1 15 amp
2. Furnace and ac 15 amp.
3. Water pump 10 amp
4. Exterior light 15 amp
5. Awning
6. Battery charge 30 amp. Am I turning off this one
2112
You don't need to turn off any breakers if your battery is charged.
If your battery is low, let it charge a few minutes before you turn on the AC. The charger may draw 4 amps for a short time
2013 KZ Durango 2857
time2roll
Yes, plug in and let it rip. Once running check the voltage is above 110 in the RV.
If the breaker overloads.... turn the fridge and water to propane only. If it still overloads let the battery charge for 60 minutes and try again.
And forget the microwave or the hairdryer. TV and lights will be OK.
If the GFCI trips.... ok that is more involved.
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Hi,
I'm comfortable running the roof air so long as voltage is no lower than 108. I monitor it with a Kill-a-Watt meter.
If it is lower than 108, I add the autoformer to the circuit.
Regards, Don
Johnsonty131
Thanks guys I slept in camper last night and dog ear never got hot, just a little warm and voltage was always over 120!
dodge guy
Bartlett IL
Are you using an extension cord? That will reduce the voltage if so. If you have a way to monitor the voltage in the trailer then keep an eye on it. It will probably be OK.
I see you already did, and it worked out. Now you know it’s time to run a dedicated 30A service for the RV.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Usually on a 20 amp (T-shaped neutral) circuit you can run 1 "Big ticket" item (A/C, Water heater, Microwave) as others have said run the fridge on Propane
And make sure the batteries are full (Give them at least 2 or 3 hours of "plugged in" time before you run the A/C)
Of course this only works if your spouse is not Eva Gabor (Reference to TV show: Green Acres)
