RV.Net Open Roads Forum: House AC went out can I hook up to 20 amp gfci
 > House AC went out can I hook up to 20 amp gfci
willald
NC
Posted: 06/14/22 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, you should be able to. But, as already said, don't run anything else when running the A/C, and be very careful about what extension cord you use, if any.
If regular RV cord won't reach the 20 amp outlet without an extension, instead of using a typical household extension cord, I'd recommend getting a 30 amp RV extension cord, and using that.
That way, you can be pretty sure that voltage drop over the cord won't be a problem, and you'll also have an extra RV extension cord you can carry with you in case you need it at a campsite later on.
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis ("Brook")
2018 Jeep Wrangler JK ("Wilbur")
jdc1
Rescue, Ca
Posted: 06/14/22 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
No one mentioned what could happen if you overload that circuit. You could burn up you AC unit ($$$).
Johnsonty131
Posted: 06/14/22 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you guys. I think I will have to hook up to my 20a outlet for a couple nights as I think it will be fine if I trip converter. Also I’m in Texas so I will just set thermostat where it stays on constantly during the night instead of coming on an off. I will have to use an extension cord but it is the exact kind that’s already on camper (the black thick one). Only doin this for 2 nights hopefully. Also how do I know if I’m burning up the circuit? Just use multimeter on the outlet im hooked up to?
midnightsadie
ohio
Posted: 06/14/22 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
all ways some idiot butting in on the 20amp read I,d put my hand on the cord close to the connection see if its warm .Texas a hot place I,m in ohio hot to us is about 80deg.
AllegroD
Outdare
Posted: 06/14/22 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
I would not run anything on the same line, in the house/garage, such as a freezer/washer/dryer in the garage.
way2roll
Wilmington NC
Posted: 06/14/22 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
midnightsadie wrote:
be nice if it was a 20amp out let, and I,d not use any thing else on that line. I run my rv ac off one with no problem.
He said it was 20A in his title.
I am guessing the statement in the actual post "I have the dog ear adapter for the 15 amp to 30" threw some people off. But yeah, 20A should be no problem.
2023 FR Sunseeker 2400B MBS
phillyg
SWFL
Posted: 06/14/22 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe 15a, but might need 20a.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
ktmrfs
Portland, Oregon
Posted: 06/14/22 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
just be careful in extension cord length and AWG. Use 12ga and as short as possible. Or best if you can just use the 30A from the trailer to a dogbone at the outlet.
2011 Keystone Outback 295RE
2112
Posted: 06/14/22 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Johnsonty131 wrote:
Thank you guys. ....
.... Also how do I know if I’m burning up the circuit? Just use multimeter on the outlet im hooked up to?
Measure the voltage at an outlet inside the camper. Make sure it stays 110VAC or above. A Kill-O-Watt meter comes in handy for this.
Hold the plugs at the GFI outlet and extension cord to see if they are getting hot. A little warm is expected.
2013 KZ Durango 2857
dedmiston
Coast to Coast
Administrator
Posted: 06/14/22 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
And make sure there aren't any coils in the extension cord.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
