time2roll
ShinerBock wrote: We will have to disagree here. They are using the truck the same way they would use and ICE truck. Just because it does not perform the same and adds hours to the trip, does not mean it isn't relevant. In every cross country review and article I have seen of an EV vehicle, they have all added time to trips. Everything has pros and cons, and currently this is a con of EV's. You can't just boast about the pros of your favorite thing and then cry foul or bury your head in the sand when a con is exposed or report on. EV long distance adds time to a trip? We knew that 20 years ago. Why would TFL even need to drive the vehicle? Just read the sales brochure and call it a fail.
Reminds me of John Broder of the NY Times. Kept short charging the EV on a multiday road test trip until it fully stalled and said it was a defective car.
675w Solar pictures back up
Lantley
Ellicott City, Maryland
valhalla360 wrote: Lantley wrote: Actually Tesla has figured out how to mass produce an EV that reliably works. That has not existed since the 1800's.
None of the major players have been able to achieve this feat to date!
Its more than just hype or old news. Tesla has built the platform that will eventually replace the ICE.
It's more of a money,mindset issue than a technical issue at this point. Tesla has established a real live working blueprint for the vehicle itself.
Sure they have...even back into the 1800's EVs were more reliable...probably even more so compared to the ICE of the day. The problem was and still is energy storage.
The Tesla I drove had no problem with energy storage. I pressed the pedal and it took off like a rocket. However the silence was erie no engine noise. No clanking, no rumbling, just swoosh. Like fast forwarding a movie things just passed by the windshield.
Did that happen in the 1800's
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
thomas201
Eastern Panhandle WV
Really battery storage is a dead end. Just look at the energy density and the infrastructure build out. Hydrogen? The embrittlement problem with common carbon steel is going to be hard to solve.
The best solution:
"esearchers from the University of Pittsburgh and the University of Rochester seek to improve this process in a project that recently received $300,000 from the Department of Defense Office of Naval Research. The project, led by the University of Rochester’s Marc Porosoff and Pitt’s Giannis Mpourmpakis, will refine a crucial step in the seawater-to-fuel process, making it more energy efficient, safer, and scalable.
The first step of fuel synthesis is converting the carbon dioxide (CO2) extracted from seawater into carbon monoxide (CO). Last summer, the team successfully demonstrated that molybdenum carbide catalysts efficiently and reliably convert CO2 to CO, achieving this critical first step in turning seawater into fuel. The newly funded project will expand on the previous work, seeking to further hydrogenate carbon monoxide into usable fuels using Fischer-Tropsch synthesis."
The hard part was making carbon monoxide. With electricity and carbon dioxide (seawater, air recapture, power plant exhaust) you can feed this through the Fischer-Tropsch process and produce hydrocarbon fuels. Germany in WWII did this, as did South Africa in the old embargo days. Then you just blend into the current gasoline and diesel supplies. This also solves the storage problem for solar and wind power generation. Just saying, think out of the box.
valhalla360
No paticular place.
Lantley wrote: The Tesla I drove had no problem with energy storage. I pressed the pedal and it took off like a rocket. However the silence was erie no engine noise. No clanking, no rumbling, just swoosh. Like fast forwarding a movie things just passed by the windshield.
Yeah, pretty much. They were expensive top of the line machines back then.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
valhalla360
No paticular place.
Now that's funny! You're able to comment on the reliability of an electric car from over 100 years ago compared to the reliability of an ICE car from over 100 years ago?
Yes, the technology is pretty well understood. The ICE back then needed regular maintenance and tune ups. They had to be rebuilt every few thousand miles. The advantage was in range (ie: energy storage).
Electric motors were very reliable. My Dad has a bench grinder hooked up to a 1920's electric motor that ran perfectly in the 1980s.
Lantley
If EV was simple 1800's technology one of the big players would have come out with a desirable EV long before Tesla. The big guys fumbled around with the Bolt and the Leaf and are still fumbling around with the Mach E (which currently has a stop sale mandate).
Maybe You can enlighten those guys with some old text books and get them moving forward with some plans from the 1800's.
In the mean time Tesla with continue to dominate the EV market.
PButler96
Midwest
Well this certainly descended into a pissing match of total silliness lol. Thanks for the laughs.
I have a burn barrel in my yard.
parker.rowe
Delaware
PButler96 wrote: Well this certainly descended into a pissing match of total silliness lol. Thanks for the laughs.
Right?
It towed the trailer very well.
Are there range issues. Yes
Is anyone surprised by that. No
Can you make it work if you change your driving habits. Probably
Does it have impressive power and is unaffected by elevation. Yes
No one is surprised by that either.
It did a great job towing the IKE and didn't break down on the road trip. But it's not for everyone.
No big surprise there. ICE vehicles will be around for a while yet for heavy work.
2015 Starcraft TravelStar 239TBS 6500 GVWR
1997 GMC Suburban K2500 7.4 Vortec/4.10
1977 Kawasaki KZ1000
Half the reason I'm on this forum is for the entertainment value....
It really is uncanny compared to other (similar-ish) forums, the sincere level of ignorance and insolence some of the folks here exude!
Reisender
NA
parker.rowe wrote: PButler96 wrote: Well this certainly descended into a pissing match of total silliness lol. Thanks for the laughs.
Right?
Great summary. And pretty much our experience after a lot of towing a little travel trailer with an EV this year.
I would also add that it’s comparatively pretty cheap to tow with an EV as well.
Cheers.
