RV.Net Open Roads Forum: Travel Trailers: Disadvantages of flipping trailer axles?
 > Disadvantages of flipping trailer axles?
jimh406
Western MT
Posted: 06/16/22 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking about flipping trailer axles on my TT. Technically, it isn't flipping but moving the spring perch and spring to the top of the axles. I know there are kits available for new perches that can be welded on.
Are there any disadvantages other than possibly having higher center of gravity. It is a relatively short in height, double axle, and aluminum skinned.
For those wondering, the dump connection is very low, so I think a few inches will help.
TenOC
On the road -- Full time
Posted: 06/16/22 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
No problem. I have flipped axles on 2 of my TT. So that the rear end did not drag. The entrance steps will be a little higher.
MAKE SURE the wheels (axels) are aligned so the tires do not "toe out/in".
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
Kavoom
Kansas
Posted: 06/16/22 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
No negatives here either. I had a single axle 22 footer same issues you have but also expands your horizons a bit. We do National Forest campgrounds dirt Nat Forest roads.
SDcampowneroperator
South Dakota
Posted: 06/16/22 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Flipping axles adds cosiderably more side load torque to the spring pack, shackles hangers and frame. An added welded in X member like 2"x .188 square tube between the rear axle spring hangers would be my advice.
Huntindog
Phoenix AZ
Posted: 06/16/22 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
I havce done it on 3 TTs. Works great, you will lose about 1 MPG due to more wind resistance. That is the ONLY downside.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
valhalla360
No paticular place.
Posted: 06/17/22 06:12am Link  |  Quote  |  Print  |  Notify Moderator
We did it on a 5th wheel. Overall positive.
One minor item not mentioned above: The rig was less stable while parked and needed to spend a little more effort at times getting the stabalizers to reach the ground solidly.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Durb
NW
Posted: 06/17/22 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Need to readjust WDH. More stress on suspension components when on curvy roads and backing up. May need a step stool for that last step down. May need blocks for tongue jack or stabilizers. Looks goofy.
Upside: easier access to underside of trailer. I too had a trailer with a low drain outlet combined with underfloor tanks. Sometimes the sewer inlet was higher than the trailer outlet requiring the dump hose to be "walked" empty. Not enough whoosh to empty the tanks sufficiently.
ewarnerusa
Helena, Montana
Posted: 06/17/22 09:59am Link  |  Quote  |  Print  |  Notify Moderator
It can make the last step from your stairs to the ground a big one. We use a sturdy stool on the ground to make up the difference. Other than that, no issues that we have noticed.
https://www.amazon.com/Camco-Adjustable-........cphy=&hvtargid=pla-4584207577681122&th=1
Aspen Trail 2710BH | 280 watts of solar | 2x 6V GC batteries | 100% LED lighting | 1500W PSW inverter | MicroAir on air con | Yamaha 2400 gen
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 06/17/22 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Mine were flipped and larger axles added. This gave me larger brakes and allowed for 16" tires to be used for better margins on weight the axles and tires could handle in addition to raising the trailer. It was a great mod.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
opnspaces
San Diego Ca
Posted: 06/17/22 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Easily 13 years on mine with no problems. I'm 6'5" so the 6 inches difference cause by the lift isn't really a problem. But I did build a 6 inch high platform for a step since most women are a bit shorter that me. If I ever buy a different trailer I will make the mod without hesitation.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
