Arn
Ottawa Valley, Ontario, Canada
9,000lb trailer with load range D tires which came on the trailer. I just had my second blowout in only a few hundred miles. Time to go to load range E in a Goodyear Endurance. Thinking the D is not heavy duty enough & thinking I need to go Goodyear. It will be nice to tow without worrying about my tires.
Arn
1958 Me
1963 Her
2015 Jayco Jay Flight 33RLDS
2020 Silverado LTZ Crew, 5.3 Max Trailering Pkg.
Owens River area
You have ruled out road hazards as the cause? Under inflation?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MarkTwain
Northern, Ca. , USA
Arn wrote: 9,000lb trailer with load range D tires which came on the trailer. I just had my second blowout in only a few hundred miles. Time to go to load range E in a Goodyear Endurance. Thinking the D is not heavy duty enough & thinking I need to go Goodyear. It will be nice to tow without worrying about my tires.
![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif) ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif) ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif) ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif) ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif) ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
amxpress
Clayton, NC
Make sure they’re properly balanced.
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
bolljl
Fulltimer
Good Choice getting Goodyear Endurance,
2015 RAM LongHorn 3500 Dually 4X4 CUMMINS
2013 Lifestyle LS35SB, MORryde IS System
AIRSAFE, Air Hitch
If you're insinuating the tires are 7-8 years old, I wouldn't necessarily blame the tires....
2017 Heartland Torque T29
ken56
Tennessee
I kept the Trailer Kings that came on the trailer for the first year we had it. Second season I noticed bulges on the side walls. We made it home taking back roads going slower than being on the E-way. Took it next day and got my Goodyear Endurance put on. Haven't worried since.
Gdetrailer
PA
If you are loading full 9,000 lbs then load range D tires are "marginal" for your needs. LRD gets you around 2100 lbs per tire at 65 PSI or 8,400 lbs..
I have a 10K flatbed trailer and it came with LR E tires which have side wall pressure of 80 PSI..
I also have a 7,000 GVWR travel trailer which originally had LR C tires which were rated around 1,700 lbs at 50 PSI. I have been running LR D tires which have about 2,100 lbs capacity at 65 PSI and for the yrs I have been using them no blow outs..
It isn't who or where the tire was made but if you are overloading and/or underinflating the tire that really is the problem.
It is very easy to blame the tire manufacturer or where it was made but in reality the manufacturer of the trailer should have spec'd a tire with more capacity.
Fished
Cedar Park, Texas
I just bought a Keystone Cougar, it had four Trailer King tires on it. The other day one blew out just sitting in the yard. It's possible that the dealer may have over inflated them. I'm getting ready to get five new Carslie tires for it from Discount Tire.
2019 Ford F150
2020 Keystone Cougar
USAF Retired
Fished wrote: I just bought a Keystone Cougar, it had four Trailer King tires on it. The other day one blew out just sitting in the yard. It's possible that the dealer may have over inflated them. I'm getting ready to get five new Carslie tires for it from Discount Tire.
Possible, yes. But highly unlikely even if they overinflated a fair bit it caused a static blowout.
