RV.Net Open Roads Forum: Tech Issues: battery to inverter wiring
 > battery to inverter wiring
voodoo101
arizona
Posted: 06/17/22 10:33am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2000 watt inverter charger running off 4 GCU 6 volt, fully charged golf cart batteries. High load appliances like the microwave quickly cause a low voltage overload. I have 2/0 cables from the inverter to the first pair of batteries and they are less than 3 feet in length. They are wired to the nearest pair. The batteries are connected with #2 awg cables. Given the price of flexible copper welding cable I am reluctant to build new cables for the batteries unless I know it is going to make a big difference. If we really need the microwave, I can fire up the Honda but I would like to be getting the 2000 watts off the inverter.
(I am also toying with getting an inverter microwave to run at lower power as an alternative.)
shastagary
minnesota
Posted: 06/17/22 10:49am Link  |  Quote  |  Print  |  Notify Moderator
i would up the gauge of the wire between the batteries and if the batteries are all next to each other it should help to connect the inverter + to one pair of batteries and - to the other pair to balance the load better between all the batteries
BFL13
Victoria, BC
Posted: 06/17/22 10:59am Link  |  Quote  |  Print  |  Notify Moderator
"First pair" sounds like the bank is not balanced by having the load across the whole bank, but instead you have a "downstream" pair that takes less than half the load. It should not be that bad though with those wires, so it could be the batteries.
Have you checked each cell in all four with an hydrometer?
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
time2roll
Posted: 06/17/22 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Get out the voltmeter and verify the situation.
Put the meter right on the inverter input terminals, note how much the voltage drops when inverter starts running. Do the same right on the battery terminals. Post the results.
Depending on the situation move the meter to detect at different places to verify connections are good.
Not sure how far the pairs are apart but this could be the issue. The near pair is probably over worked. May need to wire the near pair in parallel and then connect in series with the second pair also in parallel. The full series connection should be 2/0.
If the wiring is not changed, the close pair will be overworked even if the inverter-microwave resolves the issue with lower amps draw.
675w Solar pictures back up
voodoo101
arizona
Posted: 06/17/22 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for your replies. Yes, I regularly check the cells with a hydrometer and all are good. The voltage at the inverter drops to 11.8 which is where it will drop off line.
I built the wiring 20 years ago without a large inverter in mind. The price of flexible welding cable has jumped a bunch. Just was quoted $6.89 a foot for 0/2 flexible! I will ponder the options and do whatever makes sense. Thanks again.
CA Traveler
The Western States
Posted: 06/17/22 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Your microwave could cause a 150A battery draw which is significant. 2x 2/0 3' cables will drop the voltage about 0.1V so the rest is connections and batteries. Check each cable voltage end to end under load. Load test your batteries as they could be weak. Unbalanced loading causes more usage on the nearest pair and shorter life.
Also can you lower the cutoff voltage on the inverter?
2014 Grand Cherokee Overland
Bob
theoldwizard1
SE MI
Posted: 06/17/22 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
How many feet of 2/0 are we talking, 3', 6' (x2). Pay the money. There are places on eBay that will make up whatever you want with the proper ends.
3 tons
NV.
Posted: 06/17/22 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Cabling is your bottleneck, a very common problem that causes grief for the poor 2000w inverter…Early on, I learned this the hard way, but now likely a bit overkill at 0004, 3’ with silver soldered and crimped copper lugs, but no more inverter alarms!!
3 tons
voodoo101
arizona
Posted: 06/17/22 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons
Got it. Thanks all.
2oldman
NM
Posted: 06/17/22 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
I recommend higher voltage, like at least 24 for high draw stuff, but too late for that. Your inverter manual may specify 4/0 for that load. #2 may be a bit small for the interconnects.
