RV.Net Open Roads Forum: Tech Issues: battery to inverter wiring
 > battery to inverter wiring
BFL13
Victoria, BC
Posted: 06/17/22 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
11.8v shut off is ridiculous. Most straight inverters alarm at 11v but keep running until 10.5v shut off. You have an inverter/charger which might have settings so perhaps you can change that as suggested above.
If you have a 1v voltage drop with MW on, now you need 12.8 battery voltage to get anything. How when a full battery is 12.7?
EG I have a 1v drop with MW on, but my inverter alarms at 11v so I can run it when battery is below 50% SOC at 12.1v. Your wiring is fatter than mine and we both have four 6s.
Edit: do you have some other thing in the circuit that shuts off at 11.8? Not sure how they work, but some monitors like Victron have a way to do that?
* This post was edited 06/17/22 06:08pm by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
pianotuna
Regina, SK, Canada
Posted: 06/18/22 01:15am Link  |  Quote  |  Print  |  Notify Moderator
What make and model is the inverter?
Change the wiring to balanced.
Regards, Don
MNRon
Tennessee
Posted: 06/18/22 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Drawing large loads like 150A will have IR drop in the cabling as you’re aware, but internal resistance in the batteries will also come in to play at high loads like that. If you switch to Li you’ll not only gain an advantage of lower internal resistance, but also higher starting voltage (at an obvious cost $$)
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
Posted: 06/18/22 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Like someone else said I'd amp up the cables between pairs.
Also clean all connections.
Alas I had same issues.
