RV.Net Open Roads Forum: Class A Motorhomes: Backup camera failure
 > Backup camera failure
Coelacanth
Syracuse, NY
Posted: 06/24/22 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
O.k., I contacted the camera manufacturer. They were very helpful.
The lights are all fixed, as is the camera. I managed to splice all the wiring.
And, I covered the wires in a clear plastic sleeve called Critter Cord that smells awful and is designed to prevent pets from chewing electrical cords. Other than that I’ve got my fingers crossed.
But, for now all is back to normal.
Keeps life from getting boring?
wallynm
Los Alamos NM
Posted: 06/29/22 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Diligence has its reward! Congratulations
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Coelacanth
Syracuse, NY
Posted: 06/29/22 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Indeed.
Next up is to reconnect the generator wires that the little darlings chewed through.
It turns over, but won’t start. I suspect the electric choke may be the culprit.
The interesting part was removing the generator from the motor home.
Reinstalling it may be even more fun?
[emoticon]
Coelacanth
Syracuse, NY
Posted: 07/02/22 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Ok,…generator wiring all fixed, …I hope.
The only thing remaining before reinstall, the 120v out line.
It had to be cut in order to remove the unit. My concern is, is it safe to install 120v, 15amp male to female plugs to reconnect the line? Or, should I wire nut the ends together? Install a junction box? Or, is that overkill??
CA Traveler
The Western States
Posted: 07/02/22 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Water might be a concern so I'd use a junction box.
An alternate would be 120V 20A plugs. Even better would be a 20A twist lock plug. Vibration could be a consideration.
I'm assuming your gen is less than 3600W.
2014 Grand Cherokee Overland
Bob
Coelacanth
Syracuse, NY
Posted: 07/02/22 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Onan QG 4000.
CA Traveler
The Western States
Posted: 07/02/22 08:42am Link  |  Quote  |  Print  |  Notify Moderator
That's 33A, way over a 20A plug capacity.
Coelacanth
Syracuse, NY
Posted: 07/02/22 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Male and female 30 amp RV plugs installed.
Update: O.K.,….I removed the generator and redid all the rodented wiring. FYI, removing the generator is not for the faint of heart. I used my ATV jack, but there is almost no clearance.
Now, the generator is back in and starts right up,and will run, what seems like normal, for about two minutes. Then it dies and gives an Onan error code #3-#1-14. After that it won’t restart unless you let it sit for a while.
I checked the spark plug, just for the heck of it. It looks fine. This generator has almost no hours on it. Oil level is good. I never touched any of the carb linkage. But, I did install an inline shutoff valve in the fuel line. Might that be restricting the fuel flow?
* This post was last edited 07/15/22 06:18pm by Coelacanth *   View edit history
Coelacanth
Syracuse, NY
Posted: 07/16/22 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Update #2: I removed the inline fuel switch. A few drops of fuel dribbled from the line. I thought this was odd. I expected a flow. Does fuel flow depend on the generator’s on board pump?
Anyhow, I primed the carb. I can heard the primer pump running.
I then tried to start the generator. It fired up on first kick.
Once again it ran for two minutes and then quit. I have a feeling that it uses up the fuel in the float bowl and then just runs out of fuel.
So, should the fuel line remain empty until the generator draws fuel? And, if so, why isn’t fuel flowing? The system seems to prime normally. Could it be a generator fuel pump issue? Maybe the little critters ate a wire I missed??
Bruce Brown
Northern NY
Posted: 07/16/22 08:14am Link  |  Quote  |  Print  |  Notify Moderator
^^^ How much fuel is in the main tank? Any chance it's just low on fuel?
On a side note, I'm just an hour up the road, I have a big garage and lots of tools - and actually know how to use them. [emoticon]
If you need any help or need an extra set of eyes on something come on up.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
