garmp
St Louis, MO
Been a camper for a while, but relatively new to the RV style. 26" Class C (actually a Class B+). Pulled into our reserved camp site & set up. Slides out, leveled, water hooked up, plugged into electric (with EMS) and ready to settle in. Hotter than blazes so the air was turned on. After a few minutes we lost power. As I frantically ran in circles and turned off the air & everything else I could find the power came back on. I thought that's great. Then I looked at the EMS and saw an E2 error code. Open ground. Being electrically stupid, I thought good it foud the problem. All was clear and up & running. Turned on the air again and within a few minutes it happened again. Not knowing what to do & ringing wet from the heat I removed the EMS and plugged directly in to the power poll. All worked fine.
Was I just dumb & lucky or what. It was far too hot to do without air as DW & I are asthmatics & have respritory issues. It was getting later in the day & campgroun was full so no place to go.
Was this a totally wrong move on my part or what should I have done?
thanks
Our 2351D Phoenix Cruiser, Jack, has turned us from campers into RVers and loving it!
wanderingbob
monticeeo, fla
I am sure that there are plenty of people in that campground without an EMS , you will not be the only one ! Not totally wrong if it worked , but then I do not believe in all those gadgets
2112
Where ignorance is bliss, Tis folly to be wise
2013 KZ Durango 2857
Owens River area
You were promised by the RV park that they supplied “good” electrical power. They broke their promise and, I’ll wager, offered no refund.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
LouLawrence
Traveling the US!
IMHO, you made a mistake and should have insisted that you be moved to a power pole without an issue or they have a repairman fix the problem at the pole. You chose to ignore the insurance you paid good money for and the consequences of that decision can be devastating (or you get lucky and they are not).
We pay for protection and sometimes that protection is inconvenient but you have to assume the worst and verify that the problem is your EMS (rarely) and not the campground power (often).
agesilaus
North Florida
2112 wrote: Where ignorance is bliss, Tis folly to be wise
Had to look it up, geez that is one grim poem
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
garmp
St Louis, MO
Thanks for your opinions, mostly. I did feel that many others showed no signs of having EMSs so I thought it should work without dire consequences. Guess I did luck out. But thanks to most of you I hope to be wiser than before. To those whose inept attempt at scarcasm only reveals your lack of knowledge on the subject I feel sorry and apologize to the reading audience for you wasting their time.
I did ask, because I was trying to learn.
ken56
Tennessee
Google what an open ground is and the conditions it can cause. Google knows everything.
time2roll
Try your 50/30 pedestal adapter to get a better ground.
675w Solar pictures back up
2112
agesilaus wrote: 2112 wrote: Where ignorance is bliss, Tis folly to be wise
Had to look it up, geez that is one grim poem Man, I'm glad you understood it. I spent a week many years ago dissecting that poem in a writing class to get it.
To the OP: My sarcastic comment was directed to Wanderingbob, if it matters. His comment reminded me of that line. It means you can better enjoy your moment among the flowers not knowing what fate lies in wait.
