RV.Net Open Roads Forum: Tech Issues: Pulling new heater duct
 > Pulling new heater duct
Missionstreet
PA
Posted: 06/19/22 02:06am Link  |  Quote  |  Print  |  Notify Moderator
Looking into replacing my old smelly heater 4" duct pipe.
Is semi rigid metal pipe acceptable substitute? The only other selection I found at the "box" store was some spiral wound "foil" pipe that feels weaker that the original existing.
Also, the sections running to the bedroom and bathroom I was thinking of pulling the new in with the old. Is this a good idea?
My concern is what looks like the existence of nails under the floor that might puncture the pipe as it is being pulled.
I believe it was all open when originally assembled on the "jig."
BobsYourUncle
Calgary Alberta Canada
Posted: 06/19/22 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Replacing ducts would be a tall task. They are all joined together, there are corners and jogs etc. Existing ones likely have some kind of duct / foil tape sealing them. They will be attached to the floor in various places.
Ducts are all installed while the unit is being built, prior to assembly of floor sheeting and more.
Anything can be done, but you'd have to open up the floor to access them. "Pulling" the ducts is not an option.
IMO, the best option would be to clean the existing ducts. Get in there with some kind of flexible snake with a cloth on the end, wet with a cleaner.
You could even remove the furnace, take it apart and thoroughly clean everything.
Spiral round flexible pipe is a great dirt trap. They are full of ridges inside and air will not flow smoothly.
Have a look at the Floor section of my rebuild site, link in sig. It shows one example of heat ducts. There are many other ways they do it.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
CA Traveler
The Western States
Posted: 06/19/22 08:21am Link  |  Quote  |  Print  |  Notify Moderator
X2 They can be cleaned with compressed air and a snake.
2014 Grand Cherokee Overland
Bob
nickthehunter
Southgate, MI
Posted: 06/19/22 08:25am Link  |  Quote  |  Print  |  Notify Moderator
YOMV - but pushing any type of cleaning tool into your ducts would be a bad idea.
midnightsadie
ohio
Posted: 06/19/22 08:31am Link  |  Quote  |  Print  |  Notify Moderator
O zone your duct work.
Cummins12V98
on the road
Posted: 06/19/22 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Look to see if you have a Gensco in your area or another HVAC Supply House. They will have heat rated Grey flex duct in your size. Make sure to tell them you need the heat rated as it's on the supply side of the furnace.
Visually it is grey in color and has a rubbery feel to it. This did it's job and did not melt or ignite.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Microlite Mike
NW Washington State
Posted: 06/19/22 10:35am Link  |  Quote  |  Print  |  Notify Moderator
The ducting used in most RV's is usually flimsy and inefficient. I had to replace all mine from furnace to registers which wasn't as monumental in my TT as it could be in others.
I used a better grade of ducting that doesn't kink as easy as the factory type which seems to be just aluminum foil over a slinky.
If I were to do it again I'd use some insulated ducting like this:
With my new ducting I get more flow from the registers but a lot of heat is dissipated in areas I don't necessarily want more heat (like around the power distribution center/converter and under refrigerator) so insulation will direct more heat out into the living space.
This insulated 4" ducting is available at Lowes with a 25' piece selling for ~$40. Where the duct has to make sharp bends I'd add a metal fitting to make the bend and then just wrap it with fiberglass strip insulation and cover with Duct Tape. A little more effort and modest expense but far more efficient and easier on furnace.
As for heat in cabinet/storage areas to prevent water line freezing in cold weather, just add some ventilation louvers to the closed off areas that will both allow living area heat to travel into these spaces and also provide year-round ventilation that mitigates moisture damage.
Semi-rigid metal ducting will work but will radiate far more heat in spaces you don't necessarily want and less in areas where you do.
"Knowledge is realizing that the street is one-way, wisdom is looking both directions anyway."
~ Albert Einstein
Vintage465
Prunedale CA.
Posted: 06/19/22 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
There is a lot of good thinking behind using an actual elbow to get around a corner if it possible to do that. Problem is usually where it's that tight, it'd be stinker to try and get a elbow in there. I'm in the "mental engineering" phase of adding some ducts to cabinets so the coffee cups aren't ice cold on those 20-30 degree mornings. I also need to add a duct over to my wifes side of the dinette so she's not freezing her legs off while I roasting on my side of the dinette.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
jodeb720
Denver
Posted: 06/25/22 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
In my 5er, the plenums in teh floor were leaking from the get go. it would take 20 minutes for a 5 degree rise.
After doing some solid research and verifying it with some folks here, I bypassed the original plenum, used insulated ducting like shown in Mike's picture and now it works sooooo much better. I did have to so some imagineering to get the new ducts through the and around the cabinets, but in the end, i'm much happier.
As they say, it's not easy - but when it's done correctly, it works so much better.
Missionstreet
PA
Posted: 06/28/22 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you all this is very informative and inspiring
