RV.Net Open Roads Forum: Truck Campers: Fifth Wheel Hitch - tried searcing
 > Fifth Wheel Hitch - tried searcing
EricCO
Colorado
Posted: 06/20/22 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I'm sure this has been asked but I could not find with a search.
Want to put a fifth wheel hitch in bed that is easy to remove so I can drop truck camper in it when we want to use truck camper. Looks like the mounting rails are bolted to bed so that probably doesn't seem too easy to remove without wrenching on it.
Anything like what I'm needing exist out there?
2002 Ford F-350 CC LB PSD
2007 Travel Lite 960rx Ultra
2009 Lund 208 Pro-V GL with 250 hp Verado
Bedlam
PNW
Posted: 06/20/22 09:55am Link  |  Quote  |  Print  |  Notify Moderator
There are two-part hitches where the hitch head and cradle separate to make them lighter. Anderson fifth wheel hitches are lighter but some people feel they are not up to the task.
If your truck has pucks or a gooseneck to mount a hitch, you have almost a flat surface and not much to push up on the under side of the camper. If you have to install rails, you will need to build up the bed surface to those rails before loading the camper.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD
C.B.
APPLETON WI USA
Posted: 06/20/22 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Pullrite with under bed mount system.
(1) Remove hitch.
(2) Remove 4 mount pins.
Clear bed.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
jimh406
Western MT
Posted: 06/20/22 10:58am Link  |  Quote  |  Print  |  Notify Moderator
B&W makes a removable hitch. My bed has one from the previous owner. It all comes out, but they aren’t light.
I use a rubber mat over the hole.
camp-n-family
London, Ontario
Posted: 06/20/22 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Get an under mount gooseneck hitch and then either an Anderson or b&w companion fifth wheel for it. The b&w isn’t light weight but is a superior hitch.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
jaycocreek
Idaho
Posted: 06/20/22 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
I just put down some 2X4's and put the TC down on them..Cleared the FW rails perfectly never slipping..
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
Slymer
Ontario, Canada
Posted: 06/20/22 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
If I had to do it all over again I would go under-mount gooseneck for sure. No bed to create for the camper, which also adds height.
bolljl
Fulltimer
Posted: 06/20/22 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
We had truck camper and 5th wheel with bolted down mounting rails. I added Plywood between the rails.
Used chain host to remove Air Hitch (250lbs)
2015 RAM LongHorn 3500 Dually 4X4 CUMMINS
2013 Lifestyle LS35SB, MORryde IS System
AIRSAFE, Air Hitch
otrfun
On The Road
Posted: 06/20/22 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
When we had our 5th wheel, we were going to purchase a nice B&W hitch. When we discovered how heavy and awkward they were to move we compromised. Not fond of the Anderson for various reasons, so we purchased a hitch similar to this. It's a two piece hitch that disassembles easily by just pulling a couple pins. The top and bottom assemblies each weigh about 40-45 lbs. each. Very manageable.
To clear the mounting rails with your truck camper, you may consider using 1 or 2 sheets of plywood with portions cut-out to clear an opening for the mounting rails.
* This post was edited 06/20/22 03:54pm by otrfun *
keefr
Edmonton
Posted: 06/20/22 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Reese Elite series is another. I used one for years, a rubber bed mat gave enough additional height to clear the pucks.
Never argue with an idiot - they drag you down to their level and beat you with experience. - George Carlin
