TheLostBoy
Canada
Does anyone know if the threaded rods in stabilisers can be replaced? The nubs (or whatever they're called) on the rods that my crank slides over are worn down so far that the crank keeps slipping over it and I'm afraid one day I'm going to be stranded one day because I can't retract my stabilisers.
Fisherman
Angus, Ontario, Canada
Just have someone weld a couple of nuts on the end, then you can use a drill driver with the right socket to go up or down.
bgum
South Louisiana
Fisherman has best solution. While your there some lubrication would help.
edited 06/20/22 09:12pm by bgum *
BobsYourUncle
Calgary Alberta Canada
Another vote for Fisherman's solution. Perfect.
So much easier with a socket and cordless drill.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
amxpress
Clayton, NC
While you’re under there you might consider lubricating the threads.
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
JRscooby
Indepmo
If you have enough thread there, screw on 2 nuts, then jam them together. Work same as welding, but if you need to take it apart you can
valhalla360
No paticular place.
JRscooby wrote: If you have enough thread there, screw on 2 nuts, then jam them together. Work same as welding, but if you need to take it apart you can
You need to use a deep well socket if you go this route. Otherwise, it may just grab the first nut and break it free.
But unlikely you will ever need to take it apart, so a quick tack weld should work fine.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Fisherman
If you go the 2 nut method, a plop of thread locker will probably keep them together. Just make sure you line the 2 nuts up to allow a deep socket to cover both when cranking.
Bingo. Either will work I believe, but 1 nut on the end with a little goober plug weld on the end is the easiest if you have access to a welder or a buddy.
2017 Heartland Torque T29
Microlite Mike
NW Washington State
Shaft has acme threads on it. Standard nuts won't fit however oversized nut s can be welded on.
"Knowledge is realizing that the street is one-way, wisdom is looking both directions anyway."
~ Albert Einstein
