RV.Net Open Roads Forum: Truck Campers: Electrical Help pls
 > Electrical Help pls
Page of 5
maria_bettina
Auburn, CA
Posted: 06/20/22 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
shastagary wrote:
this is what it says on the amazon page of that inverter that i also own. it can easily draw more than 10 amps with the heater load
If the rated input of any connected AC devices exceed 150W, please use battery clamps to directly connect to your vehicle's battery as most vehicles' 12V cigarette lighter ports are rated for 150W. Do not use to power high power electric devices such as hair dryers, electric heaters, which might blow a fuse.
[emoticon] guess we will count ourselves lucky with a couple blown fuses.
I better relook at the DVD and TV wattage. Thanks for pointing this out.
* This post was edited 06/20/22 08:44pm by maria_bettina *
maria_bettina
Auburn, CA
Posted: 06/20/22 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
Inverter should draw power direct from the battery using #8 wire minimum. 250w is close to 25 amps at 12 volts.
If I bought a new inverter and connected it to the battery directly, I am still looking at 25A. Which is crazy. We have a 200Ah battery, so 4 hours of continual use (before I reach 50% battery charge)? But if that same 250 Watt heater was DC, that's a whole different story. Electricity is like magic. Totally boggles my mind! Haha
maria_bettina
Auburn, CA
Posted: 06/20/22 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
stevenal wrote:
Once the fuse blowing issue is solved, I expect you'll be dealing with battery capacity. Heating appliances will draw your battery down very quickly.
Yes, I am bummed. I don't know how to heat ourselves at night. Below 40-degrees and it's downright uncomfortable. We have a Little Buddy heater, but not for sleeping. We have Reflectix around the vinyl (we have a pop-up TC), but that's not enough.
Back to the drawing board.
CA Traveler
The Western States
Posted: 06/20/22 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Nope a 250W DC heater: 250W/12V = 20A+, ie It will draw 20A+ DC amps.
Plus the cig plug is likely rated for 8A, you need to connect the inverter more directly to the battery. About 4 hours of run time and more with solar cranking.
2014 Grand Cherokee Overland
Bob
pianotuna
Regina, SK, Canada
Posted: 06/20/22 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I am bummed.
How many amp hours is the battery bank?
The rule of thumb is multiply amps by 10 to get the draw at 12 volts. This is due to inverters being at best about 88% efficient.
If the voltage on the battery is low, the inverter may well draw even more amps, causing the fuse to die.
Generally the inverter may be sized to do 125% of the load. 250 x 1.25 = 312.5 watts (so the inverter is busting its heart out trying to run that heater).
There are a couple of solutions.
1. connect the inverter directly to the battery posts. That will eliminate the fuse and amperage issues.
2. Use a 50 heating pad instead. You could run two.
3. There are 12 volt heaters available.
In any event the batteries are not going love running the heater for long periods of time.
My first battery bank was 875 amp-hours. Heaters were not an issue.
Regards, Don
jimh406
Western MT
Posted: 06/20/22 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
You can use a Little Buddy or Buddy heater in an RV. To be extra safe, open a window. Most people just use heaver bed covers at night.
maria_bettina
Auburn, CA
Posted: 06/20/22 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I am bummed.
875 Ah? I thought ours was large - 200 Ah...
Yea, those DC heaters don't get good reviews. I looked at a couple. I will keep looking, but the Amps they use have me looking elsewhere. It's the cold air that doesn't allow me to sleep. Maybe I just need to get electrical sites when it's cold. *Sigh*
We will definitely connect the inverter to the battery directly. Now that another post said using over 150 watts needs a direct connection to the battery.
maria_bettina
Auburn, CA
Posted: 06/20/22 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have an uber safety conscious son who won't run the Little Buddy at night. I guess it could be worse. I could have a son who juggles knives or something. [emoticon]
Yes, it's the breathing the frigid air that keeps me up.
maria_bettina
Auburn, CA
Posted: 06/20/22 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Right! Math. [emoticon]
I just can't wrap my head around the high Amps.
time2roll
Posted: 06/20/22 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
Amps x volts = watts. DC or AC works the same.
Always use 12 volts when calculating because that is where the power is coming from.
Otherwise need to plug into a 120v generator.
The 12 Volt Side of Life
675w Solar pictures back up
Page of 5
